Old 04-14-2012, 06:50 PM
Jayster Jayster is offline
Default ERROR: Pro Tools LE 8.0.1
I get a errror message when I start Pro Tools, every since I activated "Celemony Melodyne Single Track". The error reads:
(The procedure entry point ??1_NonReentrantPPLLockHolder@details@Concurrency@ @QAE@XZ could not be located in the dynamic link library MSVCR100.dll) What does this mean, and how can it be repair. Also, the Celemony Melodyne Single Track has inserted it self into the "strument" tab of the plug in insert, but I was told that it should also be in the "other" tab of the plug in insert. So this program is not operating correctly. How can I fix these issues, thanks in advance.
Jayster
Old 09-14-2020, 07:15 PM
Default Pro Tools 2020.9 Interface
Can I use my MBox 2 interface with Pro Tools 2020.9. I brought Pro Tools 2020.9 and it will not recognize my MBox 2. I don't see it in the Input Device section (says, "None"). In my Device Manager under "Other Devices", it has (2) Mbox's there, with Yellow Triangle questions marks (not installed). Is this MBox 2 not compatible with Pro Tools 2020.9. Do I need to upgrade my Interface.
Thanks
Old 09-14-2020, 08:24 PM
Sardi Sardi is offline
Default Re: ERROR: Pro Tools LE 8.0.1
Bumping an 8 year old thread with a PT8 title won’t help in getting answers for PT2020.
Having said that, what machine and OS are you running? You say Device Manager so I assume is a Windows system.
You’ll need drivers for the MBox. Once Windows recognised the hardware, in theory, it should work with PT2020.9.
But... that’s a VERY old unsupported interface you’re trying to run with a brand new version of PT. At a guess, I’m going to say one of those things isn’t compatible with your OS.
Pro Tools 8: Activation code not working/Error: Data Error (cyclic redundancy check) Mattmattmatty Windows 2 05-01-2013 04:26 AM
H/W Buffer Error (pro tools error -6104) Only 1 audio track running. kieran.mia macOS 1 01-29-2013 01:39 AM
Pro Tools Creative Collection returned an error. Error: -2147213312 sirprotools 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 03-24-2011 06:17 PM
Pro Tools Creative Collection returned an error. Error: -2147213312 THAPRODUCERZ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-05-2010 02:14 PM
error#4 and error #7100, pro tools crash! audioluche Pro Tools TDM Systems (Mac) 2 06-19-2006 06:10 AM
