Old 09-27-2019, 12:31 AM
Philharmonic7 Philharmonic7 is offline
Default Pro Tools 2019.6 bug
Hey Avid,
So we found a bug when bouncing files offline. Our workflow is conforming foreign 5.1 printmaster to domestic 5.1 printmaster. We output a conformed foreign 5.1 printmaster along with a stereo downmix when completed. What we’re noticing is that the foreign 5.1 pm is about 40 samples early, while the stereo downmix is aligned/synced with the original source files. This did not occur when we had PT 12.8. We caught this immediately when we recently upgraded everything.
MacOS Sierra 10.12.6
PT ultimate HDX 3
Old 09-27-2019, 06:03 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Pro Tools 2019.6 bug
Does this also happen with realtime bounce or is it just offline?
Janne
Old 09-27-2019, 10:04 AM
BScout BScout is offline
Do you have anything on a master bus for your 5.1?
Old 09-27-2019, 03:02 PM
We did not check real-time bounce, however, if there was a section that needed to be inserted, we would arm the tracks in record and punch in. The 5.1 pm and stereo downmix is aligned when punching in. Of course, the signal path to offline bounce and recording to the print tracks are the same, which makes it odd.
The signal path and plugins used for the 5.1 and stereo bus is identical. As a matter of fact, the only thing different is the update to 2019.6. Routing, plugins and templates has not been changed. Clearly, a bug has been introduced and a patch to resolve this is quickly needed.
Old 10-01-2019, 04:25 PM
Reverting back to PT 12.8.3 now.
Old 10-01-2019, 10:27 PM
clivvy clivvy is offline
that's not the only bug there also seems to be a quantize bug since protools 11 quantize is not as tight as it use to be never had to edit and move midi notes like i do in protools 12 just wondering is any body else having these issues hope Avid is paying attention they give us some thing good but something else gets affected!
Old 10-02-2019, 04:32 AM
I don't use quantize so never seen it. And I do a lot of work in MIDI. For me quantize makes things a little too uniform but I can see where some genres might want total uniformity.
Jack
QAPLA!
Pro Tools 2019 ! abomeerza Pro Tools 2019 1374 05-14-2019 07:13 AM
