  #41
Old 11-17-2016, 01:12 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: Will this work?
You tube
https://www.youtube.com/shared?ci=YfobUvbiEaA
Daniel
  #42
Old 11-17-2016, 01:13 PM
Originally Posted by Djefvul View Post
Alright, thought I'd make an update. I bought EZD2 and have for the last 2 days trying to get it to work. Finally after some support I've done it.
I can now record with my e-drums triggering ezd in pt.
So now I wonder if anyone could tell me how I would go about splitting up the drum channels and re-direct them from ezd?
Search youtube for a video on this. Its really quite simple. Each sound in the EZdrummer MIXER can have its own output selected(at the bottom of each sound's fader). Then create stereo AUX or AUDIO tracks and set the inputs to the proper plugin outputs. Use AUX tracks if you don't feel the need to "print" the audio permanently, or record to AUDIO tracks and hide/make inactive the Instrument track(don't delete in case you need to make changes and re-record the audio).
  #43
YYR123's Avatar
And again YouTube
https://www.youtube.com/shared?ci=OAm0y18il_I
Daniel
  #44
Old 11-19-2016, 08:35 AM
ramonetl ramonetl is offline
Sweetwater has a demo video on this I found really helpful.
  #45
Old 05-02-2018, 12:34 AM
Dillon Ribeiro Dillon Ribeiro is offline
Hi
I have a Roland td-3 drum kit and module. I have seen and heard that it is possible to connect these pd-8 pads through software on my PC to trigger samples and external sounds.
I want to know how to do this since it will allow for much broader sounds and increased efficiency and ease in set-up and switching between samples while on stage. It would be better to have this than to purchase an Alesis Sample pad pro
Advice and requirements on how to set it up or which software to purchase on my PC for the module to run through will be much appreciated!
80s electronic drums Legion6789 Pro Tools 9 1 10-25-2011 05:14 PM
Electronic Drums?? Pauldeeee The Drum Room 3 04-24-2010 10:01 PM
Electronic drums 18Duffs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 11-08-2003 05:04 PM
Electronic drums & 001 gargoyle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-16-2000 04:53 AM
Drums..electronic that is.. sidereal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 09-19-2000 08:15 PM
