Pro Tools 2018 installation question
Hello!
I had to recently update my macbook pro, so I have to use 2018 now. My question is, my macbook pro still has 12.5 on it. Do I have to uninstall that before installing 2018, or can I just write over it like with other versions? If uninstall, would a simple uninstall of 12.5, and install 2018 work just fine? Thanks! Mike. |
Re: Pro Tools 2018 installation question
Writing over it is fine. You can even install 2018 next to 12.5. Just rename the current Pro Tools (like add "12.5" to the name) and it won't get touched but will move over the settings to the new version installed.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro S1 x 2, Fire Max11 x 2, Dock, iPad Air5 Mac Mini 14,12, 12 core, macOS 13.6.6 RAM 32GB, SSD 4TB, GPU 19 core QNAP TVS-872XT 148TB TB3 |
Cool! Thanks! Unfortunately, 12.5 isnt usuable/compatible with my system anymore (based on threads Ive read, and on the Avid website), so Ill have to jump to 2018 only. Thats why I wanted to make sure of the installation process regarding uninstalling 12.5 or simply overwriting, etc. Would there be any reason I would need 12.5 amd 2018 on the same computer?
I would like to install both 10 and 2018.4 on my new MBP when it arrives, doable?
Rob MBP 15 2018 macOS Big Sur 11.6.8 Touch Bar and ID 2.2GHz 6 core 8 gen Intel Core i7 processor (TBs to 4.1GHz) 32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II ........and a bowl of M&M's |
No. 10 will refuse to install on High Sierra. You could have it on the same system if you had upgraded through versions of macOS with 10 being installed on an earlier compatible version but you can't install 10 as a fresh install on a recent macOS version.
Eventually I just delete the older "Pro Tools 12.x.x.app" versions so I don't have too many in my Applications folder. That's all it takes to remove older versions.
I tried Pro Tools 12.5.1 today with Sierra and to my surprise is working! Avid said officially that it isnt supported, then I found some stuff on the Avid site that said it is supported, but only with a certain version of Sierra, so I got frustrated and just decided to boot it up and it works, so I may hold off on 2018, unless there are some really cool features that are worth the $300 reinstatement? |
Yup
Pro Tools 2018.3 / 2018.4 crashing when switching window configurations | matthewmkb | macOS | 0 | 06-27-2018 06:33 AM |
Installation Issues with Pro Tools | First 2018.3 | geist171 | Pro Tools 2018 | 2 | 04-03-2018 06:58 PM |
Pro Tools 2018 installation.. some basic questions. | tatothekid426 | Pro Tools 2018 | 5 | 03-11-2018 12:57 PM |
Pro Tools 11.0.2 Installation Question | heavyd1176 | Pro Tools 11 | 1 | 09-22-2013 11:40 AM |
Pro Tools Installation Question | croomraider | Pro Tools 10 | 1 | 06-25-2012 09:00 PM |
