Old 03-06-2012, 05:22 PM
Shevanelflip Shevanelflip is offline
Default PT probleme
I'm having real problem right now.
I can't seem to be able to record anymore. I get sounds from my interface's mixer(focusrite pro 40). My i\o Setting seems fine. I can hear playback so that fine. The inputs are correctly assigned. But I don't get any signal in the actualt pro tool track, nor does it record when it's armed.
I'm really scratching my head right now.
anybody care to help.
Old 03-06-2012, 06:33 PM
Zuzudaddy Zuzudaddy is offline
Default Re: PT probleme
Did you try enabling input monitoring ?? Just a first guess.
Old 03-06-2012, 06:37 PM
Dism Dism is offline
First:
Help us Help You - READ THIS Before Posting!
Second:
What is your recording source? Are you trying to record from a mic? Are you getting a signal in MixControl? What version of MixControl are you using? I recall there being an arming issue a while back that was fixed in a more recent version.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 03-07-2012, 08:59 AM
Based on your description, I would make sure you didn't select Input Only monitoring too. Alt-K toggles that function, and when its ON, there a little green "led" beside the main transport record button lit. Then again, it could be some setting in the Focusrite mix/monitor setup, but I don't know that little gem.
Problème clé Ilok et Pro Tools [Résolu] MaxB88 Le Forum en Français 18 03-05-2015 08:26 PM
Problème de mise à jour PT 10.3.6 jihel Le Forum en Français 2 09-25-2013 02:26 AM
Probleme with pro tool 8.0.1 timestrike 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 02-11-2010 02:29 PM
probleme -6093 at the end of bounced toffee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-22-2004 05:29 PM
S.O.S freezing probleme davidS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-03-2000 12:42 AM
