Old 02-15-2019, 06:55 AM
Tileeba Tileeba is offline
Default Keyboard works in Pro Tools 10, not in Pro Tools 11
Is there any reason why my keyboard can play Midi in Pro Tools 10, but not in Pro Tools 11.
My keyboard is connected to my computer via MIDI cables into a Steinberg UR44 audio interface. If I put an virtual instrument in a Instrument Track, my keyboard can control it in Pro Tools 10, but not in Pro Tools 11. I looked at the settings in both, and they seem the same. Any suggestions?
Thank you!
Old 02-15-2019, 09:59 AM
Default Re: Keyboard works in Pro Tools 10, not in Pro Tools 11
Multiple threads on the same subject in different subforums isn't cool and is against the TOS. Maybe the mods can remove one of them?
Jack
QAPLA!
crizdee's Avatar
crizdee crizdee is offline
Thank you!
Have you been into the various settings...
Setup>Midi>Midi input devices. does the midi interface show here?
Are you on Mac? The Mac Audio/midi setup on the midi page. is your midi device showing here?
Is the track set to record?
Under options menu>Midi thru is this selected?
Is your inst track set to view instrument? here you can select the midi input? it defaults to"ALL" but click on the the all and see if your device is select able. then select the box below it and see if its routed to your instrument.
Chris
Producer, Engineer,
www.ukmastering.com
Old 02-15-2019, 11:57 AM
Hello, crizdee. Yes, all is set up exactly like I have it set up in Pro Tools 10 (where it works). However, I just noticed that in Pro Tools 11 MIDI > Input Devices, my Steinberg appears as "Steinberg UR44 [Emulated]", while in Pro Tools 10, it is just "Steinberg UR44". Would that indicate something?
Old 02-15-2019, 11:59 AM
I meant them to be different topics, musicman691.
Here I am asking how to get MIDI working in Pro Tools 11.
In the Pro Tools 10 forum (where my MIDI *is* working), I am trying to find out if there is a way to play my Keyboard's instrument banks in Pro Tools - basically having Pro Tools control my Keyboard, and not the other way around.
They are two different questions.
Old 02-16-2019, 05:33 AM
crizdee's Avatar
Emulated suggests to me the driver isn't correct or compatible.
try re-installing the steinberg driver and check for the latest version.
Thats all i can think of
Chris
Producer, Engineer,
www.ukmastering.com
Old 02-16-2019, 05:36 AM
Thank you, Chris. I thought the same thing and have already installed the latest driver. Maybe UR44 isn't compatible with Pro Tools 11. Thank you for your suggestion, though.
Old 02-16-2019, 05:49 AM
Sardi Sardi is offline
It is definitely compatible. I’ve used a client’s one in the past.
If there’s a Core Audio or ASIO driver, it’s compatible.
Old 02-16-2019, 06:26 AM
I got it to work! I googled around and found that others have had this problem (including some with Steinberg UR44). One suggested solution was to start Pro Tools 11 as administrator. I did that, and, although my audio interface still shows up as "emulated", it is now working. Thank you for your suggestions and help, everyone!
WTB TC Works Tools TDM JuanPC Buy & Sell 4 07-02-2015 12:03 AM
Pro Tools Midi: External Keyboard Input to Piano Roll's Keyboard SupreGlu MIDI 1 05-16-2015 08:26 AM
Midi Control Not working in Pro tools 11.0.1 but works in pro tools 10.3.6??? bleudog Pro Tools 11 17 04-30-2014 03:13 PM
How Pro Tools Works Mountain_king Eleven Rack 3 01-06-2013 09:53 PM
What works on Pro Tools 7.4 HD Ray Lyon Pro Tools TDM Systems (Mac) 1 02-03-2011 06:44 PM
