Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 11-17-2017, 11:54 AM
elmodagansta elmodagansta is offline
Default Digi003 with High Sierra
Greetings DAW creatures. I have problems accessing my Digi003 on High Sierra. Has anyone tried already? The PT is not listing Digi as as a device in Playback devices. Looking forward to any comments. Regards
Digirack 003 + ProTools12
Mac mini 2014; SSD 128; i5 2.6; 8GB; OS 10.13
Old 11-17-2017, 12:32 PM
AlexLakis AlexLakis is offline
Default Re: Digi003 with High Sierra
I believe there was another 003 user who was having the same troubles with High Sierra, but the search function on the forum isn't working for me right now.
Old 11-18-2017, 02:45 AM
Yeah... it was me :) I just made a new thread with clear description of problem. Hope someone will share.
Wysłane z iPhone za pomocą Tapatalk
Old 11-25-2017, 01:30 AM
Default Re: Digi003 with High Sierra [SOLVED]
If anyone is interested I managed to get Digi003 to work on High Sierra. It was my obvious mistake - Security prompt poped up during Digi003 installation and I ignored it. Solution is : go to "Security and Privacy" in System Preferences. There was a prompt that Avid was blocked. Clicked "allow" and it's working perfectly. Probably something obvious for Mac users. For me it's a discovery. cheers
Old 12-04-2017, 04:56 PM
Useruseruser Useruseruser is offline
I'm having the same issue. My Mac on High Sierra can't see my 003 Rack. What did you do to install yours?
Old 12-04-2017, 07:05 PM
Southsidemusic's Avatar
He just told you in the post above your post ....
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 12-04-2017, 07:20 PM
Mine doesn't show there. It doesn't show anywhere hence asking how he installed it. Are you running a 003R on High Sierra?
Old 12-04-2017, 07:27 PM
Nope. We would not run High Sierra until it is supported.
What do you mean by "Mine doesn't show there" ?
Are you looking for a step by step to install a Digi003 on high sierra?
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 12-05-2017, 12:38 PM
Following the OS version compatibility with Pro Tools 12 I wanted to downgrade the OS to Sierra 10.12 but luckily I failed to do so (my bootable version of Sierra was not booting). So I kept on forcing the 003R to work with High Sierra. You can see the result in the attached image. Check if there is nothing blocked in the "Security & Privacy" tab in the System Preferences. Good luck
Old 01-07-2018, 01:29 PM
kierinho kierinho is offline
Hi. I am having the same problem where High Sierra and ProTools are not recognising the 003 Rack+.
There is nothing being blocked in Sys Prefs and it is not showing in Profiler.
Could you perhaps expand on what you did to 'keep on forcing' it to work?
Many thanks.
S6L AVB with OS X High Sierra brinnbacka VENUE Live Sound Systems 3 10-20-2018 12:52 AM
High Sierra jon9 Eleven Rack 0 11-16-2017 03:35 AM
High Sierra yet? mlavin00 Pro Tools 12 18 11-13-2017 10:09 AM
12.8.2R2 on High Sierra TrentWilliams Pro Tools 12 3 10-21-2017 10:09 PM
