Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools SE and Essential (Mac)
Old 05-24-2011, 04:51 PM
aimeet aimeet is offline
Unhappy "Error on Quickstart" (Nothing is working!)
I have a Macbook OS 10.5.8
I just completely erased the hard drive and reinstalled and have a back to factory settings Macbook! I did it just for this. I want it to be only used for my Music.
I just installed the ProTools SE 8.0.3 and have the M-Audio 2nd Generation MobilePre.
When I go to open Pro Tools I keep getting the "Error on Quickstart" Message!
I am getting really frustrated. I have done everything, I have installed the new patch and I ran the Shockwave fix...but nothing seems to work.
Also I found this zip file with a Shockwave fix, but when I go to unzip it and install it says error I need to log in as administrator. I am already logged in!
I am getting really frustrated and about to return the whole thing all together. As this has already taken me over 3 hours of troubleshooting. ughhh....
Anyone know of any other ideas or have any other fixes?
Thanks!
Old 05-25-2011, 09:57 AM
barrax barrax is offline
Default Re: "Error on Quickstart" (Nothing is working!)
I'm having the same issue. This really needs to be sorted out asap!!
I've done everything from uninstalling shockwave, re-installing pro tools SE, updating the latest FastTrack driver (applicable to my OS X version) and applying the 'fix' supplied here... still getting the message:
'Error occured while starting QuickStart.'
System: Mac OS X, 10.6.7
Installed:
Pro Tools SE 8.0.3 (bundled CD)
Applied Patch:
Pro Tools SE 8.0.3 Patch 002 (Mac)
FastTrack driver downloaded and applied:
FastTrack_OSX_1_8_1.dmg
I've now been 2 days trying to fix this - please someone there help us!!
Old 05-25-2011, 10:08 AM
Hey luckily... i twigged that it could be a problem with the flash player and that somehow the shockwave installations are interfering with the flash installs...(which QuickStart relies on).
IT WORKS!!! - all i did was:
1.) remove shockwave (using the installer/uninstaller from adobe)
http://kb2.adobe.com/cps/158/tn_15895.html
2.) was gonna uninstall pro tools SE but didn't bother - BUT this is still the installation WITH the patch applied:
http://www.m-audio.com/index.php?do=...5020442061ea89
3.) Downloaded the latest Flash Player:
http://get.adobe.com/flashplayer/
4.) Crossed my fingers and hoped it would get past this Quickstart hurdle... AND IT DID!!
Really hope this helps you guys out - good luck!
B
Edit: I had to re-install from the CD - using the standard versions of Pro-Tools and the FastTrack driver (long story). This time it worked fine.. i honestly think people just need to re-install flash to resolve any conflicts that affect QuickStart..that's it. No patch needed as far as i know!?
Old 05-27-2011, 10:06 PM
thanks!
I actually just got it to work. I ended up uninstalling Pro Tools...then I installed the Patch and then I reinstalled Pro Tools and now...it works!
Phewwww.....
"error occured while starting QuickStart" please help! chloetyn Windows 0 01-26-2012 11:37 PM
Pro tools 9 crashes at startup "Bus error" in thread "MainThread", at address 0x0 danball macOS 2 09-26-2011 04:49 PM
PT9 Session Troubles - "Bus Error" in "Main Thread" & Could not complete the Open... tohmit macOS 5 03-23-2011 12:13 PM
Error 7053, "Wm exception". "TDM ProcessTypeGlues"(!) and SoundToys greyed out ! LSNY macOS 1 02-08-2011 04:16 PM
8.1 - Intermittent "Engine not responding" error when working with Reason via ReWire Rammelt Pro Tools TDM Systems (Mac) 0 08-18-2010 01:03 PM
