Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 11-06-2017, 09:05 PM
Neiko Neiko is offline
Default 2017 About connecting two AVID S3 boards together to have 32 faders!!!????
What is the possibility that you enable the S3 of AVID so that it can be connected in conjunction with another S3, in order to have 32 faders?
I own an S3 and a Protools Dock, but I am obsessive with the symmetry and when the dock is set aside, it looks horrible and asymmetric, also, to mix and i need at least 32 faders.
The Artist Mix if they allow to connect in chain, up to 4 of them, why the S3 can not?
One solution would be to buy an S6 system, I know, but the price difference between S3 and S6 is astronomical, so I can put together an S3 set ($ 5000) + DOCK ($ 1200) + S3 ($ 5000) of 32 faders and a master control for $ 11200, an amount that would not even reach half of an S6 of 32 faders. The cheapest thing you have is the AVID S6-M10 and its price is around $ 18500 and it only has 16 faders, I guess for the 32 faders we would be talking about more than $ 25,000 dollars.
Please, personally I love the S3 + DOCK, enable to connect two S3 and thus be able to have 32 DAW control faders. What should we do to make sure that is in their plans?
Att. Neiko
Producer, Composer & Artist
Mexico DF
November 2017
¿que posibilidad hay de que ustedes habiliten la S3 de AVID para que esta se pueda conectar en conjunto con otra S3, para poder tener 32 faders?
Soy propietario de un S3 y un Protools Dock, pero soy obsesivo con la simetria y al quedar el dock a un lado, este se ve horrible y asimetrico, ademas, para mezclar yi necesito almenos 32 faders.
Las Artist Mix si permiten conectarse en cadena, hasta 4 de ellas, ¿por qué la S3 no puede?
Una solucion sería comprar un sistema S6, lo sé, pero la diferencia de precio entre la S3 y la S6 es astronómica, con lo que puedo armar un conjunto S3 ($5000) + DOCK ($1200) + S3 ($5000) de 32 faders y un control maestro por $11200, cantidad que no me alcanzaría ni para la mitad de una S6 de 32 faders, Lo más barato que ustedes tienen es la AVID S6-M10 y su precio ronda los $18500 y solo tiene 16 faders, supongo que para los 32 faders estariamos hablando de mas de $25000 dolares.
Por favor, en lo personal me encanta la S3 + DOCK, habiliten para poder conectar dos S3 y asi poder tener 32 faders de control DAW. ¿Qué debemos hacer para que eso esté en sus planes?`
Att. Neiko
Productor, Compositor & Artista
Mexico DF
Noviembre 2017
Old 11-06-2017, 09:15 PM
Default Re: 2017 About connecting two AVID S3 boards together to have 32 faders!!!????
or an option is to make an S3 Extension that is equal to the S3 only without the audio interface that comes with it, that I definitely do not use it and I assure you that many do not either.
o una opción es hacer una S3 extensión que sea igual a la S3 solo que sin la interfaz de audio que trae incorporada, que definitivamente no la uso y les aseguro que muchos tampoco.
Old 11-07-2017, 09:09 AM
At this point in time, its not possible. Avid knows of the desire(I've been asking since the S3 was introduced) but, so far, it seems to be nothing more than a hope. If you just gotta have 32 faders, the only solution I can see would be to sell the S3 and add 4 Artist Mix units and place 2 on each side of the DOCK
Old 11-08-2017, 08:29 AM
EddieJones's Avatar
Yes, I did post somewhere else about this. We turned this on to test a couple of months ago and found many issues that would take months to fix. Obviously, we would like to sell more S3's so its on the list but I can't say when at this time.
Old 12-15-2017, 11:07 AM
Ru_C Ru_C is offline
yes, i ask about this each year at the U.K BVE show.
It would be the most affordable route out of PT10HD & a 32 fader Pro Control for me, as the S6 is out of my price range.
I think AVID would sell a lot more if they could do this
A Rig: (Studio) I7-7700k Hackintosh - OSX 10.15.7, PT Ultimate2023.6 Native PCI-e Card, AVID I/O16 Analog i/o x2, 40 fader D-Command ES
B Rig: (Home/Office). M1 Mac Studio - 64gb ram - OSX 12.7.1, PT Ultimate2023.6, HD Native Thunderbolt, Omni, Avid Artist Control
http://www.lostboysstudio.com
Old 04-02-2019, 01:14 PM
RichR RichR is offline
The ability to link 2 S3s would be incredible and a guaranteed sales boost for Avid. It would in no way take buyers away from the S6 as they are priced in a totally different stratosphere for S3 users. PLEASE DO IT!!
Old 04-02-2019, 08:12 PM
uptheoctave uptheoctave is offline
It will never happen.
Old 12-11-2019, 06:35 PM
abc1mce2's Avatar
abc1mce2 abc1mce2 is offline
+1
What is more relaxing than Music?
Pro Tools Carbon for macOS 12.7.4
My HDX for Windows11.
Gigabyte Z490 Vision D - BIOS F21b
Intel Core I9 10850K Windows11 / macOS 12.7.4 Hackintosh / 32GB of Rams
Avid Carbon/HDX 2024.3 Ultimate - 8x8x8 HD I/O - PT Dock - PT Control - Artist Mix (1)
Universal Audio Apollo Twin|X - UAD2 Pci-E and Satellite USB Octo v.11.0.1 - SOLO 610 - Twin-finity
Bricasti M7 (2)
Lexicon PCM96
Neumann KH805 - KH310
Yamaha NS-10M
Avantone Mixcubes
Grace Design M905
Etc, etc, etc.
Old 12-14-2019, 06:25 PM
At least now you have a solution. Sell the S3 and get 4 S1 units. 32 faders(plus the DOCK if you like).
Avid Profile Fader Bay Circuit Boards failing [email protected] VENUE Live Sound Systems 1 12-13-2015 11:07 PM
Avid/Digidesign Pro Control 16 Faders (Main Unit + 8 faders pack) Eduardo Apolonia Buy & Sell 3 11-24-2015 09:56 PM
Connecting an Avid S3 Hurricane89 Pro Tools 11 2 10-09-2015 02:16 PM
OTher DAW not connecting to AVID Core Audio ArKay99 Pro Tools HDX & HD Native Systems (Mac) 1 02-19-2015 09:18 PM
DAE Error 728, when connecting AVID Mojo headroomstudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-31-2009 06:25 AM
