Old 07-07-2018, 06:16 PM
tourtelot tourtelot is offline
Default Mounting Two Artist Mix
Hi. Hope this is the correct forum.
I travel with two Artist Mix controllers and I haven't found the appropriate case to hold the two, mounted together, or a quick way to mount them up in a sturdy manner. Screwing two Artist Mix units together looks great whaen they are on a table but the plastic tabs are bound to break off sooner rather than later if the two are mishandled in any manner.
I machined an aluminum backing plate that secures the two units to a non-flexible base and makes the two units very sturdy when mounted together. It's just too long for any casing solution that will keep them paired up so far as I have found.
So I am looking for users' tips on how to travel with a pair or Artist Mix controllers and not need to screw and unscrew them in and out of every gig.
Anyone have any cool ideas?
Thanks.
Doug
Douglas Tourtelot, CAS
Seattle, WA
Old 07-07-2018, 10:50 PM
its2loud its2loud is offline
Default Re: Mounting Two Artist Mix
Look for a Keyboard hard case that might hold the Mix’s. Its about the right depth and you could probably use any extra space in the case for the power bricks.
https://www.guitarcenter.com/Road-Ru...ith-Casters.gc
Old 07-08-2018, 04:44 AM
Southsidemusic's Avatar
Maybe somethibg like this : one in each case as a big case for both might be harder to lug around.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Can I change Eucon Layouts with an Artist Mix or Artist Transport? amathie Artist Series 10 09-21-2017 07:29 PM
Artist Chat window in Avid Artist Community taylor4814 Pro Tools 2018 0 01-25-2017 06:30 AM
2 avid artist mixes and one artist control V2 for sale Brandonx1 Buy & Sell 2 03-21-2016 09:55 PM
HDX1, 8x8x8 I/O, Artist Mix, Artist Transport, AAX DSP plugs ArKay99 Buy & Sell 8 03-22-2015 01:12 PM
Touching Artist Transport Freezes Up Artist Control in Logic sonofmack Artist Series 1 03-13-2013 08:22 PM
