Unable to Open Session Komplete Audio 6
I am having a lot of trouble with this audio interface in Pro Tools 11.
I believe it is related to the sample rate, and the inability to set it in the ASIO control panel. At first I was getting 'unable to initialize audio device' but I got around this by selecting it by holding 'n' and changing a few settings including 'ingore errors' Now I am in the seesion, and everthing looks normal, all outputs are showing in the I/O panel, however playback does not work. The program basically crashes. please help. The audio interface works completely fine in Reaper Cheers. |
Re: Unable to Open Session Komplete Audio 6
Hello Steve088,
Regards, RC |
I'm having a similar issue. It's always been temperamental to change sample rates with PT and the Komplete Audio 6. But recently, with PT 12.1, it simply will not play a session I have at 41. It will work with 48 sessions.
All other audio software will switch sample rates no problem. Only PT has an issue. I'm running PT 12.1, Win 7 64-bit, and the KA6 with the latest drivers. Any other thoughts?
Scotty Huff Nashville, TN Main DAW: Dell XPS 8900, Win 10 Pro, 16Gb RAM, UA Apollo Twin Duo Vienna Ensemble Pro Slave: Dell Precision T3600, Win 7 Pro, 64Gb RAM, VEP 64-bit |
On Window, try making your onboard soundcard the default for Windows sounds/audio and leave the KA6 - or whatever interface you're using for Pro Tools - only for Pro Tools.
Also note, with some/most third party interfaces and Pro Tools, it's a two step process to change bit/sample rates: interface then Pro Tools. Cheers, Cheers,
Unable to Open Session | mundo66 | MIDI | 0 | 11-10-2006 08:27 AM |
Unable to open session from the session icon | jah-d | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 01-21-2004 06:00 PM |
Help - unable to open session G4/500 HD PT5.3 | letrev | Pro Tools TDM Systems (Mac) | 4 | 05-15-2002 12:52 AM |
unable to open a session | zagreb | Digidesign Hardware & Software | 0 | 12-06-2001 08:31 AM |
Unable to open or save a session | Doug Judd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-31-2001 10:40 AM |
