Old 05-30-2019, 07:36 AM
Patill Patill is offline
Default Getting all confused...want to update PT9
Hi everybody,
sorry for starting a new thread since this may have been discussed very often before but the more I read about it the more confused I get
Very simple concern...I have Pro Tools 9 at the moment and want to update to the latest Version possible:
- without loosing any features
- without having to pay monthly
It seems like it is not possible to get the permanent licenses directly from Avid anymore. Is it true that PT 11 is the last one with a permanent license? Is it safe to get this license via Ebay?
Also I read here, that there are still permanent licenses for the latest Pro Tools (which is confusing me a bit...). Is this true? Does it come with limitations then? Because this is not what I would want.
Thanks for your help.
Old 05-30-2019, 08:11 AM
Sardi Sardi is offline
Default Re: Getting all confused...want to update PT9
No. That’s incorrect.
You can still buy a perpetual license to Pro Tools with the current version being 2019.5.
https://www.avid.com/pro-tools/upgrades-and-renewals
Choose the second option and you’re all set. You get the latest updates for a year. After that, you have to renew your annual update plan to access new versions. Bear in mind, if you don’t renew your plan, you’ll effectively be buying the software at full price at a later date.
Please note, it’s not a rental plan. If you decide to let it lapse withiut renewing, you keep the last version you have access to perpetually.
Old 05-30-2019, 08:55 AM
Really?? Nice, I also like the pricing for this :). Thanks for the answer, this is making me quite happy now^^
Is it also possible to use an earlier version (PT 10 or 11) with this purchase? Otherwise I may get problems with compatibilities (I have a Mac Early 2008 :eek)
Old 05-30-2019, 09:42 AM
crizdee's Avatar
crizdee crizdee is offline
Run the trial and see how it goes. Not sure your computer will run the latest OS needed though.
The link is on the same page as the upgrades above
Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 05-30-2019, 01:53 PM
Originally Posted by crizdee View Post
Chris
If that 2008 is a cheesegrater the max Apple says it'll run is El Crapitan.
Jack
QAPLA!
Old 05-31-2019, 03:56 AM
yes it is. That´s why I wanna run it with PT 10/11 :)
Old 05-31-2019, 02:56 PM
Led Led is offline
You can run 10 on the same system, but not 11
Andy Evans
Sound Designer/Composer/Mixer
Melbourne, Australia
www.mud.net.au
Old 06-01-2019, 04:34 AM
Jack
QAPLA!
Old 06-01-2019, 02:48 PM
Led Led is offline
Originally Posted by musicman691 View Post
Maybe I should have said it as IF you want to run PT12 on your system, you can only run 10 at the same time , not 11.
So , you can run 10 and 12 or 10 and 2018 or 2019 on the same computer, or you can run 10 and 11 on the same computer but not 11 and 12, or 11 and any of the later versions ie - 2018 or 2019.
Installing any version from 12 on will remove the installation of 11, but leave 10 on there.
You also should install 10 before you install any later versions.
Andy Evans
www.mud.net.au
11.0.3 update compatibility - I'm confused musicman691 Pro Tools 11 12 12-10-2013 09:13 PM
Bit confused PT9 with CPTK update to PT10 Rob_A Windows 1 10-27-2011 08:38 AM
Confused over the 8.0.3cs2 update lowlevelowls 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-01-2010 07:31 AM
im confused about 7.4 update scuffle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-16-2008 03:01 PM
:confused: Confused Re: Expansion Chasis BA Studios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-26-2008 08:24 AM
