Old 04-25-2019, 03:52 PM
jgiannis jgiannis is offline
Default HD OMNI optical inputs
The HD OMNI has 2 optical inputs on the back.
I have the TV plugged into one.
I have the computer plugged into the other.
The TV works. The computer doesn't. When I swap the cables, the computer works, and the TV doesn't.
Is there something I'm missing, or does this sound like a broken input?
Also, on the front of the OMNI, I'll select "IN" on the meters. 5-6-7-8 all seem to have the same input. I was hoping that one of the optical inputs would play through 5-6, and the other would play through 7-8. But it looks like only 1 of the 2 inputs is working, and it outputs to 4 channels.
Any tips on routing this thing?
Old 04-25-2019, 07:19 PM
BScout BScout is offline
Default Re: HD OMNI optical inputs
Right in the manual:
Optical (S/PDIF)
Either set of Optical I/O ports can also be used for two-channel Optical S/PDIF input and out- put with support for sample rates up to 96 kHz. HD OMNI can receive two channels of Optical S/PDIF when operating at sample rates of 176.4
and 192kHz, but sample rate conversion (SRC) is automatically enabled for this feature. The Opti- cal (S/PDIF) option can be selected in the
Pro Tools Hardware Setup dialog.
Using Optical S/PDIF (which is what TVs use) you only get 2 channels.
You only get 8 channels with ADAT. In S/MUX 2 or 4, the second ADAT is used. But you aren't using ADAT protocol in the first place.
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 04-26-2019, 11:24 AM
Yeah I saw that part of the manual but its no help.
When I plug the TV into the left port, it works (while the other port is empty). When I plug the TV into the right port, it doesn't (again, while the other port is empty).
Ideally, the TV (or any compatible source) would work in either port. And ideally, I would have 2 sources, one in each port.
The more I think about it, the more im convinced that I have a busted port. I just hate to admit it.
Old 04-26-2019, 01:36 PM
Top Jimmy's Avatar
I've not used the Omni but for both ports to be usable, there would have to be 2 stereo S/PDIF paths configurable in the hardware setup. If there's only 1, then only 1 port is usable and the manual is unclear.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Sierra 10.12.6.
Pro Tools HD 2018.12, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Old 04-26-2019, 01:40 PM
There is only one. (what I was trying to point out earlier)
The lack of clarity is "either" in the manual but it should actually only be port 1.
In addition to other comments, are you aware that the OMNI can only USE 8 IO at a time?
Old 04-26-2019, 01:45 PM
Top Jimmy's Avatar
Yep, I understood that. Just trying to help the OP put 2+2 together and not conclude that his interface is faulty.
James Cadwallader
Old 04-26-2019, 03:04 PM
Here's a pic of my Hardware Setup.
And here's what's happening:
left port (while the right port is empty):
- I plug in the TV. It works.
- I plug in the computer. It works.
(In both of these situations, on my VU meter, channels 5-6-7-8 are working when "IN" is selected).
right port (while the left port is empty):
- I plug in the TV. It does not work.
- I plug in the computer. It does not work.
(In both of these situations, on my VU meter, channels 5-6-7-8 are NOT working when "IN" is selected).
File Type: jpg Screen Shot 2019-04-26 at 3.01.01 PM.jpg (37.3 KB, 0 views)
Old 04-26-2019, 03:39 PM
jjnssn jjnssn is offline
Do you have a screen shot of the mixer you can share?
____________________________________________
W10 Pro / X99 / E5-1650v3 / 64GB ECC / nVidia P1000 / ASUS TB3 AIC
PT HDX1 / OMNI / HD IO 16x16 / 11R / Kontakt Kontrol S49 / Artist Transport and Mix / UAD OCTO Satellite, Apollo Twin MKII &, x8P Thunderbolt
[Late 2013 10.14 MacBook Pro]
Old 04-26-2019, 03:41 PM
Top Jimmy's Avatar
In your picture, you have the same input selected for channels 5-6 and 7-8. If there’s a 2nd S/PDIF available, it has to be selected in one of the input pairs.
James Cadwallader
HD Omni Optical GaryCar Pro Tools HDX & HD Native Systems (Mac) 1 09-10-2015 07:52 AM
MacBook Pro Optical out into Omni optical In? KenSluiter Pro Tools HDX & HD Native Systems (Mac) 2 01-14-2015 04:37 PM
omni - how to use both optical inputs simultaneously? lemieux Pro Tools HDX & HD Native Systems (Mac) 4 10-07-2014 08:39 PM
Trim Optical Inputs on OMNI? dwaynedelario Pro Tools HDX & HD Native Systems (Mac) 13 03-13-2013 01:34 PM
192 : MUST select Optical format for Bay 3 to activate Enclosure Optical inputs????? el biciclista Pro Tools TDM Systems (Mac) 2 07-09-2002 10:32 AM
