Old 01-21-2019, 04:49 PM
kirkbross's Avatar
kirkbross kirkbross is offline
Default Re: No sound from record enabled track when low latency monitoring is enabled
I'm experiencing the same issue – I can hear my bass in the record-enabled track, but if I set it to Low Latency Mode the audio disappears, whether playing/recording or stopped.
Apogee Symphony Mk II, everything to Out 1-2 (Stereo) -> Playback 1-2.
Pearlman Church Microphone > Great River MP-2NV > Warm Audio WA-76 > Apogee Symphony MK II 8x8+8MP > PT2018 on 2018 Mac Mini with 32GB of RAM running Mojave.
Old 06-21-2019, 11:40 PM
GeneOuse GeneOuse is offline
Have you found a solution to this problem? I'm experiencing similar problems and cannot figure out how to get it working.
Old 06-21-2019, 11:51 PM
BScout BScout is offline
LLM means monitoring your record tracks from your audio hardware and not from ProTools. That is why it is low latency. ProTools mutes those record tracks so your audio hardware can take over so you don’t hear it twice.
You need to see what/how Apogee Symphony handles this monitoring or if it can even do direct hardware monitoring.
Next you should read the Pro Tools User manual on LLM. This isn’t an “issue”; this is the way it works. Not all audio hardware does direct monitoring in which case LLM is not for you.
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 06-22-2019, 01:35 AM
Led Led is offline
What Bscout said, LLM disables monitoring through protools on the record enabled track, so you need to turn up the input fader on the software mixer for your interface to hear it. Avid interfaces will do this automatically, others you need to do it yourself.
Andy Evans
Sound Designer/Composer/Mixer
Melbourne, Australia
www.mud.net.au
Can't hear audio on record-enabled track with 'Low Latency Monitoring' selected EricWillhelm Pro Tools 10 6 01-10-2015 12:34 AM
MASSIVE CLIPPING/HISSING SOUND from record enabled instrument line in track surferdeac 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-09-2012 06:15 AM
ADC Audible Latency When ANY Instrument Track Is Record Enabled Intransit Pro Tools TDM Systems (Mac) 13 09-15-2011 03:07 AM
No sound from track while it's record enabled. Fryder 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-12-2010 09:24 AM
Buzzing Sound When Track Record Enabled Rushmore 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-16-2007 04:40 PM
