Old 08-21-2017, 11:34 AM
benergy benergy is offline
Default Midi dropout/voice stealing issue in Pro Tools 12.5
Recently upgraded from 11.3.1 to 12.5 and most things are rocking right along. However, a maddening thing is happening with regard to Midi Merge recording on Midi and Instrument tracks. Say I'm programming some drums. I play in a kick-snare pattern for a few bars and quantize it as I wish. Now, time to play/merge in cymbals and hi-hats over said kick-snare pattern. Hitting a midi note that coincides with the pre-recorded kick or snare hits causes those hits to not play at all. Makes it very difficult to add midi to existing midi whether it's drums, piano or whatever else. Midi Merge is selected and no midi is disappearing or being overwritten, it's just not playing back when new midi is being triggered over top while recording. Doesn't matter if you have one midi track or 50 midi tracks in the session or if it's Kontakt, Arturia, Slate, whatever other kind of software instrument one might run. Doing the same thing but on an Instrument track fixes the issue in SOME instances, but there are many times where I have large banks of things open in Kontakt and don't care to have 30+ instances of that running. Anyone else having this issue?
Old 08-21-2017, 11:55 AM
john1192 john1192 is offline
Default Re: Midi dropout/voice stealing issue in Pro Tools 12.5
so simply, you saying that midi merge is NOT working on your system ?? is this happening in a blank session with One Midi Track ?? just want to make sure i am not reading this wrong as it is a tad confusing .. can you state it a little simpler .. like: from a Fresh Session ..
1) make a midi track
2) record some notes - kick and snare
3) turn on Midi Merge - add some notes - hi-hat
4) result .. for example: no notes were added or ???
it will make it easier for us to Reproduce your issue if it is truly an issue ..
if you wish to send me a session that i can reproduce with simple midi, i am happy to test for you .. PM me ..
john
OS 10.12.6 for PT 11.3.2 & 12.4 & above
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.12.6 - PT 12.4 & above
lynx AES16e-SRC & Aurora 16
Artist Transport & iPad - Pro |Control - EuCon 3.7 (older Euphonix Branded MC Transport)
Old 06-06-2019, 09:49 AM
How's this for slowest response time ever? Eesh. Thanks for replying and here's the simplified version...
1- Create new session
2- Create either instrument track or midi track playing Kontakt inst on an aux
3- Record a pass of midi (with midi merge already on, as I never turn it off).
4- Record a second/overdub pass of midi on same track and previously recorded notes don't play back when you trigger a new note at the same time (as you would to play in a cymbal hit over a kick drum, etc).
5- Playback track and all notes play back fine.
May also DM you as you previously said since this is such a late update to the original post!
Old 07-03-2019, 12:43 AM
EdwardG's Avatar
EdwardG EdwardG is offline
still happening here...
Pro-Tools 8 stealing control surface away from rewire'd reason. Intuition Pro Tools M-Powered (Win) 1 01-07-2010 04:29 PM
Logic 8/PT7.4.2 - Audio dropout issue psycho_monkey Pro Tools TDM Systems (Mac) 0 12-29-2009 09:59 AM
MIDI Dropout -Ryan- MIDI 0 07-15-2007 08:47 PM
7.3 Audio Dropout Issue ericfergus Pro Tools TDM Systems (Mac) 6 01-01-2007 05:21 PM
Voice Dropout, I think? Orange Worker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-10-2004 09:22 PM
