Go Back   Avid Pro Audio Community > Other Products > Pro Tools Express on Windows
Old 07-13-2017, 02:52 AM
live83 live83 is offline
Default Express - Can't locate hardware
Hi guys,
I wanted to test times per tools compared to ableton live, however, says pro tools that it does not find an audio interface! At ableton live 9 is the asio driver synonymous impeccably? Where is the error?
System:
SiSoftware Sandra
Nr
Hostname : Ableton9
Arbeitsgruppe : WORKGROUP
System
Modell : ASUS All Series ASUS MB
Serialnummer : System Serial Number
Gehäuse : Default string Desktop
Hauptplatine : ASUS X99-DELUXE II
Serialnummer : 160571264400169
BIOS : AMI (OEM) 1601 02/22/2017
Intel vPro : 9.01.37.1002
Gesamtspeicher : 32GB DIMM DDR4
Prozessor(en)
Prozessor : Intel(R) Core(TM) i7-6800K CPU @ 3.40GHz (6C 12T 3.86GHz, 3GHz IMC, 6x 256kB L2, 15MB L3)
Sockel/Slot : FC LGA1150
Chipsatz
Speichercontroller : Intel Xeon (Broadwell-E) DMI2 99MHz
Speichercontroller : Intel Xeon (Broadwell-E) Memory Controller 0 - Target Address/Thermal/RAS 99MHz, 4x 8GB DIMM DDR4 2.64GHz 256-bit
Speichercontroller : Intel Xeon (Broadwell-E) Target Address/Thermal/RAS 99MHz
Speichermodul(e)
Speichermodul : Kingston/Micron KHX2666C15D48G 8GB DDR4 PC4-21300U DDR4-2666 (15-17-17-35 7-60-20-7)
Grafiksystem
Monitor : Samsung SyncMaster
(1920x1080, 7.2")
Monitor : Samsung U28E590
(3840x2160, 27.7")
Grafikkarte : NVIDIA GeForce GTX 960 (8CU 1024SP SM5.2 1.13GHz/1.39GHz, 1MB L2, 2GB 6GHz/7GHz 128-bit, PCIe 3.00 x16)
Grafikprozessor
CUDA GP-Prozessor : NVIDIA GeForce GTX 960 (1024SP 8C 1.13GHz/1.39GHz, 1MB L2, 2GB 6GHz/7GHz 128-bit)
OpenCL GP-Prozessor : NVIDIA GeForce GTX 960 (1024SP 8C 1.13GHz/1.39GHz, 128kB L2, 2GB 6GHz/7GHz 128-bit)
Compute Shader Prozessor : NVIDIA GeForce GTX 960 (1024SP 8C 1.13GHz/1.39GHz, 1MB L2, 2GB 6GHz/7GHz 128-bit)
OpenGL Prozessor : GeForce GTX 960/PCIe/SSE2 (2GB)
Physische Speichergeräte
Corsair Force GT (60GB, SATA600, SSD) : 56GB (F:)
SanDisk SDSSDA240G (240GB, SATA600, 1.8", SSD) : 224GB (G:)
WDC WD5000AADS-00S9B0 (500.1GB, SATA300, 3.5", 32MB Cache) : 466GB (D:)
Samsung SSD 950 PRO 256GB (256GB, PCIe1/3x4/NVMe, SED) : 238GB (E:)
Samsung SSD 950 PRO 256GB (256GB, PCIe1/3x4/NVMe, SED) : 238GB (C:)
Ultra Fit (16GB, USB3/NVMe) : 15GB (H:)
Logischer Speichergeräte
OCZ 60GB (F:) : 56GB (NTFS, 4kB) @ Corsair Force GT (60GB, SATA600, SSD)
San Disk (G:) : 223GB (NTFS, 4kB) @ SanDisk SDSSDA240G (240GB, SATA600, 1.8", SSD)
X-Ableton (E:) : 238GB (NTFS, 4kB) @ Samsung SSD 950 PRO 256GB (256GB, PCIe1/3x4/NVMe, SED)
Festplatte (C:) : 237GB (NTFS, 4kB) @ Samsung SSD 950 PRO 256GB (256GB, PCIe1/3x4/NVMe, SED)
ESD-USB (H:) : 15GB (FAT32, 8kB) @ Ultra Fit (16GB, USB3/NVMe)
Festplatte : 450MB (NTFS, 4kB) @ SanDisk SDSSDA240G (240GB, SATA600, 1.8", SSD)
WD500 (D:) : 466GB (NTFS, 4kB) @ 2x WDC WD5000AADS-00S9B0 (500.1GB, SAS/SATA300, 3.5", 32MB Cache)
Peripherie
LPC Hub Controller 1 : ASUS Wellsburg LPC Controller
Audio Gerät : PNY High Definition Audio-Controller
Audio Codec : nVidia 0072
Audio Gerät : 6656 Universal Audio Apollo Twin Thunderbolt
Laufwerkscontroller : ASUS Wellsburg 6-Port SATA Controller [AHCI mode]
Laufwerkscontroller : Samsung NVMe SSD Controller
USB Controller 1 : ASUS Wellsburg USB xHCI Host Controller
USB Controller 2 : ASUS Wellsburg USB Enhanced Host Controller #2
USB Controller 3 : ASUS Wellsburg USB Enhanced Host Controller #1
USB Controller 4 : 8738 DSL6540 USB 3.1 Controller [Alpine Ridge]
USB Controller 5 : ASUS ASM1142 USB 3.1 Host Controller
USB Controller 6 : ASUS ASM1142 USB 3.1 Host Controller
System SMBus Controller 1 : Intel ICH SMBus
System SMBus Controller 2 : Intel MCP5-E(P) XMB Ch 0 SMBus
System SMBus Controller 3 : Intel MCP5-E(P) XMB Ch 1 SMBus
Drucker- und Faxgeräte
Drucker : Send to Microsoft OneNote 16 Driver (1200x1200, Farbwiedergabe)
Drucker : Microsoft XPS Document Writer v4 (600x600, Farbwiedergabe)
Drucker : Microsoft Print To PDF (600x600, Farbwiedergabe)
Drucker : Brother PC-FAX v.3 (200x200)
Drucker : Brother MFC-J4510DW Printer (600x600, Farbwiedergabe)
Drucker : Brother Generic Jpeg Type1 Class Driver (600x600, Farbwiedergabe)
Scanner und Kameras
Scanner : Microsoft Brother MFC-J4510DW [30055c0f79d3] (Scanner, USB)
Scanner : Brother MFC-J4510DW LAN (Scanner, 2400x2400, USB)
Peripherie
Media Player : SanDisk Ultra Fit (14.89GB)
Betriebssystem
Windowssystem : Microsoft Windows 10 Privat 10.00.10586
Kompatibel mit Plattform : x64
Asus Deluxe II Mainboard
Intel Core i7-6800K
32 GB Ram
UAD 2 Solo PCIe
UAD Apollo Twin MK II Thunderboldt
Arturia Minilab MK II
Arturia Drumbrute
Moog Minitaur
Maschine JAM
Windows 10 64 Bit Version 1511
Ableton Live 9 Suite
Pro Tools First
Old 07-13-2017, 06:11 AM
Southsidemusic's Avatar
Default Re: Express - Can't locate hardware
Try launching PT with the N key held down and when popup window comes up choose your interface there and see if that helps.
Best Regards
Christopher
South Side Music Group
WEBHOME
Pro Tools Express can't locate hardware. apoltorak6 Pro Tools Express on Windows 14 07-09-2017 10:08 AM
Pro Tools Express cannot locate MBox2 hardware Victorzk Windows 2 11-03-2014 07:30 AM
Pro Tools Express unable to locate hardware Sven80 Pro Tools Express on Mac OS X 1 06-03-2014 12:59 PM
Pro Tools Express Unable To Locate Hardware Psychic Denim FireWire and USB Audio Interfaces (Win) 1 06-21-2013 07:00 AM
Pro Tools Express 10.3.3 unable to locate hardware cfmfam Getting Started 2 05-16-2013 05:09 PM
