Old 12-30-2012, 07:06 PM
Squid Vicious Squid Vicious is offline
Default Record bass w/ Ampeg SVX - just plug bass into MboxPro or go in w/ DI like SansAmp?
Greetings,
I recently purchased Ampeg SVX. I've only plugged in a Fender P Bass Deluxe straight to the MboxPro to record a test track etc. Ampeg SVX sounds pretty good. I want to record a legit song I need to do bass on so I was wondering if I should just plug in direct to pro tools and use the Ampeg SVX plug in or should I use a SansAmp bass driver going in to the Mbox along with the Ampeg SVX plug in?
Thanks for any input in advance....
Old 12-30-2012, 08:12 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default
I prefer the bass driver or some other type of compressor - in the input -
It gives the sound a slightly processed quality - instead of relying on the internal effects
Daniel
Old 12-30-2012, 08:20 PM
Default Re: Record bass w/ Ampeg SVX - just plug bass into MboxPro or go in w/ DI like SansAm
There's really no right OR wrong way to do it(IOW, try everything). How I do it: I record the bass with a direct box onto an audio track, with EQ III 1-band for a hi-pass(around 50 to keep the phones from farting out at volume) and BF76 to shave off the peaks(remember that these plugins are affected what you HEAR, not the audio as it records). Then when its time to mix, I add a mono AUX track and a send from the Bass track, to the AUX track. I insert SVX on the AUX track and usually end up with the B-15 model. For me, with the AUX send at -0, AND the AUX track(with SVX) at -0, the blend of DI track and amp sim track feels right(I save this for mix as I don't want delay compensation on as it can less with the track timings). Since the DI track feeds the amp sim POST-faer, I only need to adjust/automate the DI track while mixing(the blend remains the same because of the POST fader setup). Sorry if some of this might seem redundant or obvious, but I don't know your skill/experience level and want to cover it for newbies
Old 12-31-2012, 02:35 AM
Sounds good guys. My head would think to add Ampeg SVX as a plug in on the bass track and not as a 'send' but maybe I will give that a shot too.
Old 12-31-2012, 05:38 AM
ejwells's Avatar
ejwells ejwells is offline
Agreed. I never have used an amp sim on an aux track as a send/receive, always as an insert.
Pro Tools 10.3.3 | HD Native | HD I/O 8x8x8 | Mac Pro 8 Core Westmere | 24GB RAM | OSX Lion 10.7.4 | API 3124 | Chandler TG-2 | UA 4-710d | Empirical Labs Distressor EL8X | Kemper Rack |
Old 12-31-2012, 09:45 AM
Craig F Craig F is offline
the blend of DI for detail and the power from the amp sim usually is better than sim alone
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 12-31-2012, 09:58 AM
ejwells's Avatar
Default
Duplicating the track is preferable (to me) for blending.
Sent from my SCH-I510 using Tapatalk 2
Old 12-31-2012, 11:04 AM
YYR123's Avatar
Default
Good info but I would think also depends what u want ur final out to be ?
It would change things if ur looking for clean with body
Or if ur looking for grit with power
Daniel
Old 12-31-2012, 11:57 AM
elicious elicious is offline
how would you (or the bass player) do it live ?
keep the chain the same...
e
ihatetyping
Old 12-31-2012, 01:07 PM
YYR123's Avatar
Default
e
I think he means using a live bass instead of a midi bass sounds and a keyboard
Daniel
Eleven Rack Expansion Pack Bass Demo (Ampeg SVT) VaiSatchAtrucci Eleven Rack 25 03-28-2011 12:52 PM
IK Multimedia AMPEG-SVX bass plug-in GaryC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 04-03-2009 10:56 PM
whoever thinks sansamp sounds good on bass.... da BaSsTaRd! 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-03-2004 08:02 AM
sansamp bass di badperson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 09-12-2003 07:54 AM
You use the SansAmp for Bass?? Sounder Tips & Tricks 15 07-20-2001 12:09 AM
