Go Back   Avid Pro Audio Community > Other Products > The Drum Room
Old 10-27-2009, 01:35 PM
phoenixisland phoenixisland is offline
Default using BFD as sound for triggered drums?
Greetings,
I'm new to triggered drums.
I have ddrum triggers and alesis trigger i/o + protools and was wondering if I can use BFD as the sound module.
I've got it working with the signals but when i hit a drum BFD plays a drum beat (a part of one of the grooves no doubt) instead of just a single drum hit.
I'm not finding any docs on this and any info would be greatly appreciated.
also what other drum software will let me play my drums without the automated drum playing. All the products I've read about highlight how they basically play drum parts for your songs.
thanks
Old 10-27-2009, 02:17 PM
77pro 77pro is offline
Default Re: using BFD as sound for triggered drums?
Originally Posted by phoenixisland View Post
Greetings,
thanks
I'm using BFD2 with a Roland TD4 kit to track drums for a band right now. It works great once you set up a key-map for the kit.
There should be a preset for the alesis, if not just make one. Play a trigger,see what midi note it generates and map accordingly. You can clear all the pattern triggers, although they are usually seperate from the single hits.
There's some great vid's on the fxpansion website for mapping hihats etc.
We couldn't get the cymbals triggering as accurately as the drummer wanted as he plays a lot of intricate stuff...so I'm using real cymbals along with the v-drums.
Hats off to albee1952 for steering me in this direction
003r/i7-930/LE 8.0.1 cs2 on xp
Old 10-27-2009, 08:13 PM
Thanks for the props. The only problem I have with the cymbal triggers(really liking the new Alesis Surge cymbals BTW), I can't get ezdrummer or SD2 to play a choked cymbal. The solution is to play it regular and move the midi note to the choked note.(they work perfectly with the onboard Roland cymbals).
Old 10-28-2009, 07:06 PM
Make sure that Pro Tools isn't set to filter out the poly and mono aftertouch... that's the default.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Can Strike be triggered with recorded drums? MLE Virtual Instruments 4 12-04-2012 09:45 AM
Connecting Triggered Drums to MBox2 PRo JORdanDrivE 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-01-2008 03:27 PM
Quantized Triggered Drums w/ Live overhead recording.. RyanUsesThis General Discussion 9 03-22-2007 04:34 PM
Can BFD Drums be triggered from a PT MIDI Track? DRLAudio Virtual Instruments 6 01-29-2007 09:13 AM
Triggered Drums / Sampler options tld Tips & Tricks 22 01-17-2001 07:09 AM
