Go Back   Avid Pro Audio Community > Other Products > The Drum Room
Old 10-13-2009, 06:05 PM
td7474 td7474 is offline
Default Disabling Patterns???
I like to use Strike as a drum machine, triggering individual samples on the keyboard. However, while tracking I always seem to inadvertently hit a key that triggers a pattern, screwing up my take. Is there any way to disable the patterns or mute them so that if I mistakenly hit one nothing will happen?
Thanks!!!
Old 10-13-2009, 06:44 PM
danander11 danander11 is offline
Default Re: Disabling Patterns???
Thanks!!!
If I understand correctly...
Here's what I do.
Create an instrument track and insert Strike on it. Open strike and select the KIT you want to use. Close the Strike window.
Create MIDI track. Set the OUTPUT of the MIDI track to STRIKE Channel 2.
Whatever you create in the midi track will now trigger individual drum/cym samples in Strike instead of patterns.
Once you have everything the way you want it for the song, you can record an audio track of the stereo out of Strike, or send out of Strike individual channels to audio tracks, (ie: kick, snare, hh, etc...)
Go to Russ's AirUsersBlog and watch the videos there. There is some good info on routing Strike channels.
Peace!
Here I am,
after time not long...
and thankful for the break,
What I found when I got there,
was that I couldn't stay away!
Hobo Shave!
Old 10-14-2009, 08:07 AM
RussUK RussUK is offline
Correct!
I work with amazing people who do amazing things.
Founder of the Expert Sites.
How to connect patterns? S2KING Pro Tools SE and Essential (Mac) 1 04-27-2010 06:23 AM
Vacuum Arp patterns Gothboy Virtual Instruments 1 07-08-2009 08:12 PM
Win XP: BIOS disabling or Device Manager disabling ?? mandal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 11-23-2007 03:11 AM
can you tap out patterns/create patterns in strike 4thfloorstudio Virtual Instruments 4 09-15-2006 11:14 AM
Displaying Arp. Patterns? filosofem 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 07-23-2006 11:38 PM
