Go Back   Avid Pro Audio Community > Other Products > The Drum Room
Old 10-11-2009, 10:31 AM
zv yoda zv yoda is offline
Default Overhead mic technique - what works for you?
Hi folks,
Great to see the drum room finally open. My home set up is a 12 x 12 ft room. I have to track & mix in the same room (no alternative). It has some treatment, but still sounds like a 12x12. Ceiling as about 7-8 ft high.
My question relates to overhead mic positioning... I've tried the usual techniques & would love to hear what works best for folks.
- XY over centre of kit. Does the job, but no sense of space. I find panning the close mics just gives a false sense of space
- Recorderman. Tried this recently. I like the way it projects the crack of the snare & the physical layout of the kit... but I found some phasiness in the cymbals
- Spaced pair (3:1 rule?). I think I would like this best if I could get it to work... but the cymbals sound very harsh (because the mics are lower than with the other methods)
I also close mic each drum. I constantly switch between overheads vs. closed as the main source & can never make up my mind. I’d like mostly room/overheads (and just use the close mics to fill it out) but in reality, the room ambience isn’t great, so I often EQ out the bottom end from the overheads & leave mainly cymbals coming through.
So, what works for you? Any suggestions on how I could fix the cymbals harshness/phasiness?
My kit is a maple Pearl Session Custom (10, 12, 14 & 22) with a 14x5 Master maple snare. I use various cymbals (Sabian AA/HHX & Zildjian A custom/Z). Mic-wise:
  • AKG D112 & SM57 on the kick
  • SM57 on snare (top only – never did use the bottom track, so stopped micing it)
  • Rode NT5 matched pair for overheads.
  • I have cheap Thomann mics on the toms (for now... Beyer Opus 88s on order!!... and an Octopre LE with ADAT to replace my ADA8000)
Thanks!
My music
Hardware
21.5" iMac 2.5GHz i5 (mid 2011), 003 rack, Roland TD12KV, Command8, Axiom 61,
Maxtor OneTouch4 FW/750Gb/16Mb/7200rpm (audio/session drive)
WD 1TB MyBook Studio (backup)
Software
OSX 10.7.5, PTLE 9.0.5, Superior Drummer 2.2.3, Miroslav Philharmonic Classik, SampleTank 2.5L
Waves Gold, CLA, JJP, Maserati, T-RackS CS Grand, Massey Tape Sat & DTM, Cytomic The Glue
Amplitube 3, Ampeg SVX
Old 10-11-2009, 12:27 PM
Digitopian Digitopian is offline
Default Re: Overhead mic technique - what works for you?
Hey Yoda, regarding the spaced pair.... there is nothing that says you can't raise the overheads higher. I'm not really sure how you are trying to apply the 3:1 rule in this situation but if you are not having phase issues and you raise both your overheads to the desired height by the same amount then it would seem that you would achieve your goal.
What I do regarding Spaced pair situation, and have seen a number of other engineers do the same is find a middle point in the kit. Some use the center of the snare, and I have heard others using the kick pedal as a reference point and make each OH equidistant from that point. Using this center point as a reference is at least in theory supposed to avoid phasing issues.
I have never heard of recorderman technique, so if you could share how that method works it would be great. I am always looking to try new mic'ing techniques.
Also, there is a technique known as the Glyn Johns method which many people have used to great success and if you google it you'll find a ton of info about it.
The only other thing I can think of is that if there is any possible way to change the dimensions of the room by putting up some sort of make shift wall perhaps from the wall to and through one of the corners of the room so that it is not a perfectly square 12' by 12' room may help. Any sort of offset at all would probably help as a perfectly square room is far from ideal because everything is perfectly parallel. Anyway just some thoughts....
Edit: Oh last thing, It has been my experience that even in really nice large well treated tracking rooms with high ceilings I just about always end up using a HPF to roll out some of the lows out of the OH's because of some of the strangeness that occurs regarding hearing the delayed kick drum etc, in the overheads.
Hopefully more duc'ers will chime in!
Mac Pro Quad-core 2.6, 5 gig ocz ram,1Tb hd internal, OSX 10.5.7, 2 internal Audio HD,lacie 500 gig external fw 800 drive
Digi 003 rack, PT le 9.0.1, Mac Book Pro 2.4ghz I5, 4 gig ram, PT 9.0.2, Apogee duet
Waves gold, and ssl plugins /Reason4 /miroslav philharmonik /stylus rmx /Melodyne /T-racks3 deluxe / Strike /Massey compressor, DTM /Sound Toys /blah blah etc.
UA610 pre's / Chameleon Labs 7602mkII pre's / Chameleon labs 7802 stereo opto tube compressor/ Mackie hr824 monitors
Old 10-11-2009, 01:52 PM
Trazan Trazan is offline
Well, it depends on style, room etc etc, but I usually use something similar to ORTF over the drummers head.
Old 10-12-2009, 11:54 AM
Here's another suggestion; First, set the kit up so its NOT in the center of the room(a square room will have major issues in the center). Now, assuming the ceiling is drywall(ie NOT acoustically treated), put your overheads on tall booms, spread them apart to observe the 3:1 rule(mics 3 times farther apart as they are from the cymbals) and angle the mics up(45-60 degrees) toward the ceiling. Now raise them as close to the ceiling as possible without actually touching. What this creates is the same effect as a boundary mic and it will eliminate a lot of phasing issues with sound that enters the mics AFTER bouncing off the ceiling(think about what happens ABOVE your overhead mics in a small room).
Old 10-13-2009, 09:12 AM
TOM@METRO's Avatar
Criss crossing a pair of 451s centered about 10-12 feet from the floor at the center of the kit can add some interesting imaging.
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2019.5 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 10-13-2009, 09:20 AM
Yes indeed, but hard to do with an 8' ceiling
Old 10-13-2009, 09:27 AM
EGS's Avatar
EGS EGS is offline
What works for me? To avoid phase issues, I use a single OH mic. I position it over the right knee of the drummer (left for a lefty drummer). I hang it fairly low, maybe 2 feet higher than the drummer's head. Hi-pass at 200hz. This only works if the cymbals are naturally balanced. That is, if one cymbal is louder than the others, you'll have problems. It's powerful and never phasey. Drummers love the sound !!!
Desktop: Win 7 / GIGABYTE GA-X58A-UD3R / i7-980X hex @ 3.9GHz / 32GB / PT 9 / Focusrite LS56
Laptop: Win 7 / HP ProBook 4730s / i7-2630 / 8GB / PT 9 / U-PHORIA UMC1820
Info/Services link
Old 10-14-2009, 11:19 PM
Craig F Craig F is offline
I like an SM-2 over the kit
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 10-15-2009, 12:14 AM
TOM@METRO's Avatar
That's what saws are for.
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
Old 10-15-2009, 12:22 AM
TOM@METRO's Avatar
That’s what saws are for.
With low ceilings try loosely tacking a few garbage bags or a plastic tarp to the ceiling. This can disturb HF reflections just a little and improve phase anomalies.
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
overhead compression skwad Tips & Tricks 2 12-21-2006 10:08 AM
overhead mic placement Jasperdog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-01-2005 05:41 AM
Overhead mic placement????????????????????????? jeam25 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 09-12-2003 08:46 AM
Only 1 Overhead Mic??? Big Tyme 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 04-05-2003 12:58 AM
overhead mic question sipi1910 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 01-07-2003 11:38 AM
