Old 11-26-2017, 02:59 PM
Matt Darcy Matt Darcy is offline
Default ilok via a usb hub ?
I'd like to have my ilok plugged into a USB hub plugged into my mac.
However everytime I open pro-tools 12 with my ilok plugged into a usb hub the license fails to be detected and I have to plug the ilok into the mac directly, this wastes a port on the new macs with only 2 usb ports.
Have any of you got the mac working with a usb hub and the ilok plugged in to it ? what hub did you use ? did you make any software changes to get it detected ?
thanks.
Old 11-26-2017, 03:07 PM
Southsidemusic's Avatar
Default Re: ilok via a usb hub ?
We have two usb hubs on each tashcan mac and one usb2 hub for the ilok only onmy brand new MBP and all works great.
However on one of the trashcans we had to get a powered hub as the trackball and midi interface was on the same hub it lost ilok connection too many times to not do something about it.
Check for powered usb2 hub for ilok as usb3 has issues of its own.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 11-27-2017, 08:34 AM
Dan IceWood Dan IceWood is offline
What speed USB hub are you using ?
Old 11-27-2017, 08:57 AM
Just a normal USB2 hub. The less fancy the better for ilok keys
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 11-27-2017, 09:10 AM
I know that USB3 used to be a "no go" for iLoks, but for the last 3 months(or more) I have 3 iLok 2's in a USB3 powered hub with zero issues(yes, its connected to a USB3 port on the PC). I do think you probably NEED a powered hub
Old 12-02-2017, 03:31 AM
that would be really disappointing if you "need" a powered usb hub,
I've also had the same issue with my ilok using usb port on a powered thunderbolt 2 dock.
The amount of hassle and pain iloks cause on a day to day basis is shocking.
Old 12-02-2017, 04:20 AM
I actually like having a powered USB hub - gives me a place to plug my cell phone into to charge it when I'm working.
Old 12-02-2017, 04:25 AM
wasting a plug socket just for the ilok is very unappealing
Old 12-02-2017, 04:30 AM
May be unappealing but if you need it so you can work than appealing goes out the window.
Old 12-02-2017, 04:40 AM
Drew Mazurek's Avatar
iLok cloud licenses will make this a thing of the past. Well, at least they'll be different hassles! :)
www.drewmazurek.com
FS: Pro tools HD9 transferable to Ilok account €250 (paypal and ilok fees included) Mikek33 Buy & Sell 1 12-02-2014 04:39 AM
ilok issues - ProTools 9 crossgrade LE (Please install the iLok Client Software) pauledwards Windows 3 09-10-2013 04:02 PM
Plugin auth weirdness - guest iLok prevents internal iLok? Scott Helmke VENUE Live Sound Systems 3 09-07-2011 07:06 AM
Can You Transfer iLok Licenses To A New iLok If Your Old iLok Is Broken? epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 09-07-2009 03:51 AM
Transfer iLok auth. from old iLok to new 003 factory iLok? lamp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-20-2007 07:05 PM
