Old 05-07-2018, 07:01 AM
Jon1 Jon1 is offline
Default count in intermittently changes speed during record
When recording a track, the click often (but not always) changes speed during the count in. It will eventually reach the correct speed but not always in time for me to catch the groove before "punch in". I have the count in set for 2 bars. I do not create tempo changes and I have checked there are none spuriously added at the beginning of the tempo track as well.
It doesn't happen every time but the "searching" it does when it occurs is a bit annoying since I have to try again. Does anyone have any suggestions or a remedy? Not the end of the world but this is not how it is supposed to work.
Thx so much, John
Old 05-07-2018, 07:05 AM
Default Re: count in intermittently changes speed during record
BTW I have an HP computer running XP with Pro Tools 8. It's only been doing this count in speed change for last month or so. Everything works fine otherwise.
John
Old 05-07-2018, 08:51 AM
amagras amagras is offline
Sounds like you are using different time signatures. Disable count in and use pre-roll instead. Ctrl+K
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 05-07-2018, 06:34 PM
As far as I know all my music is in 4/4. I haven't knowingly adjusted any settings that would change the time signature. I will have to look into this. thx. amagras.
Track count per drive, record function Fritz Pro Tools TDM Systems (Mac) 2 02-21-2011 10:43 AM
2 Bar count before record Tony Royal General Discussion 5 11-10-2009 02:15 PM
Intermittently dropping in to record on playback tinfoil Pro Tools TDM Systems (Mac) 0 05-12-2006 02:15 AM
count in click on record not working Bill Pillmore Pro Tools M-Powered (Mac) 0 02-21-2006 09:03 PM
002r Record Playback Count Dog BBQ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-08-2003 08:57 AM
