Re: Low Latency Monitoring and Hardware Inserts
The situation I am describing happens with NO tracks in Record or Record armed.
This happens when attempting to BOUNCE TO DISK, and / or during playback, as it pertains to the RTAS following the Hardware Insert having no effect on audio....
Brian Dozoretz ACSR ACI Dolby Atmos Mac Pro, os12.6.3, PT 22.12 HDX, 2xAlphalink,1xDeltaLink, Mac Mini, os12.6.3, PT 22.12 HD Native + HD Omni, Artist Series Mix x 2, Artist Series MC Transport, Atmos 5.1.4 VENUE SC48 3.2 with iPad Control SSL Duality SSL Duality via ipMIDI / ∂elta Automation Plug-In |
For example, I had a full mix setup >Drum Kit, Bass, 3 guitars and vocals, all assigned to 1-2 (1-2 is also my LLM output). Enable LLM and all the drums start flamming like crazy. Master fader plugs are bypassed for everything, and the mix is a general mess. This is a session that won't run for me with less than a 256 sample buffer Work around was to use a different output pair for the mix, and 1-2 only for the overdub. Reference Guide gives vrey little info about such things.
HP Z2 Xeon 6 Core, Blackmagic Decklink HD Extreme 3D Win10, PT ver.. Latest |
Latency Compensation on Hardware Inserts | BJosephs | macOS | 6 | 07-11-2011 06:45 AM |
Third party hardware and Low Latency Monitoring | The Dougfather | Pro Tools 9 | 3 | 11-05-2010 07:03 PM |
latency when using hardware inserts (oo3) | earmeter | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 07-14-2008 06:38 PM |
[002R] Hardware Inserts Latency: how much is it? | HotRats_Reloded | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 06-14-2006 01:03 PM |
latency on hardware inserts | vtone | Tips & Tricks | 4 | 10-22-2000 05:37 AM |
