Old 10-06-2016, 08:12 AM
Knmus09 Knmus09 is offline
Default 11 Rack MacOS Sierra "driver update coming?"
As of now I can't get my Eleven rack to be recognized by the new Mac OS update, OS Sierra. I went back to using OSX Maverick's. It worked up to El Capitan, but I'm assuming that it's a driver issue and the newest driver released isn't compatible with the new OS Sierra. The newest driver was made for up to El Capitan of course, but now I am waiting on Avid to release a new driver for the Eleven rack before I will update my Mac Os to Sierra. The newest driver was released on May 11? 2016.
Has anyone be able to get their eleven rack to work with OS Sierra?
Waiting, waiting, waiting...
Old 10-07-2016, 08:06 AM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: 11 Rack MacOS Sierra "driver update comming?"
Originally Posted by Knmus09 View Post
. Has anyone be able to get their eleven rack to work with OS Sierra?
Good catch....let's hope this drops soon. I really love my eleven rack editor.....
Daniel
Old 10-10-2016, 03:32 PM
anthonylbest anthonylbest is offline
I am in the same boat. Can't get drivers to work with Sierra. Even after multiple reboots.
Old 10-10-2016, 08:12 PM
Sometimes in the past installing the driver in compatibility mode works but that can cause issues between Pro Tools and the hardware driver, so I just choose to run an older version of OS until Avid updates the driver. I really hope they do. I just check the drivers, nothing new yet, last update was May 12, 2016 and that's compatibility up to El Capitan. Something to note is that my Mbox mini works, no driver update necessary. But, I also had a Seagate external harddrive that wouldn't connect into Sierra but connects fine with Mavericks and El Capitan. Sierra seems to be picky about USB connections.
Old 10-19-2016, 11:39 PM
Just an update: I've managed to get the Eleven Rack to work with Sierra now. I was using the Eleven rack with OSX Mavericks and then one day the device wouldn't connect with the driver same as with Sierra so I figured the issue isn't with Sierra but something else. I manually uninstalled the Eleven Rack because the Uninstaller that comes with the Installer wasn't working. Then I installed the 1.2.8 (not most recent 1.2.9) driver. I don't know if maybe there is a bug in the 1.2.9 update so went one back and now it works with Sierra.
Here is a link to manually uninstalling, though it's not specifically for Eleven Rack, also proceed with caution. (I don't actually know what I'm doing, I just mess around with things until they start working again )
http://http://avid.force.com/pkb/art...S-X&popup=true
Also the drivers are on Avid's pro tools support hardware drivers page.
Old 10-19-2016, 11:42 PM
Sorry the link may not work. It's on Avid's Knowledge Base page if you search "How To: Manually Uninstall Avid Audio Interface Driver Components Mac" you should be able to find it.
Old 10-20-2016, 05:15 AM
YYR123's Avatar
You have just revealed the secret to the world
Daniel
Old 10-20-2016, 08:46 PM
Default Re: 11 Rack MacOS Sierra "driver update coming?"
I can confirm that the 1.2.8 driver is working. I have no idea why this works but thank god you found this. Thank you x 100000000000
System Details:
MacBook Pro 15", iMac 27"
OSX Sierra 10.12 Sierra
ProTools 12.6
Avid Eleven Rack
Old 10-21-2016, 04:10 AM
In my past experience with Pro Tools it has been if I have troubles with an updated version I step back one update and it works just fine. For example in the past Pro Tools 10.2.something wasn't working so I went back to 10.1 and it worked like a charm. I'm assuming some Avid (not saying it's just Avid, as it just seems to be the way of software in general) updates come with bugs and glitches, then you have the choice to either keep trying, step back to the update that was working or wait for the next update to fix the bugs/ glitches in the past most recent update, and hope that that newest update has only fixes and no glitches.
Old 10-26-2016, 12:27 PM
Benoni's Avatar
Benoni Benoni is offline
Exclamation Re: 11 Rack MacOS Sierra "driver update coming?"
Eleven Rack driver 1.2.12 for OSX is now out. Supports Sierra 10.12
http://avid.force.com/pkb/articles/d...n-Rack-Drivers
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Mbox Pro 3 not working with MacOS Sierra Focuret FireWire & USB Audio Interfaces (Mac) 57 04-17-2018 11:22 PM
PT on macOS Sierra? eesn Pro Tools 12 66 10-01-2016 11:46 PM
macOS Sierra 10.12 not yet supported Avid Technical Alerts 0 09-20-2016 10:34 AM
Bug in Digi Core Audio Driver? Driver update coming? mgbasinski 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-10-2003 08:59 PM
