Old 04-01-2016, 12:45 PM
VRS VRS is offline
Default PT 12.5 Video Engine
Sorry for the long post.
I've installed 12.5. Works fine until I try to load video.
I load a session that has an h.264 video track and a ProRes video track.
"The video engine had an unrecoverable error.
Would you like to reinitialize the Video Engine"
I select "Yes" of course.
Then I get "Pro Tools encountered an error quitting the Video Engine" with an "OK" button. So I select "OK". Then I get the same error, and I click OK.
I get "Waiting for the Video Engine to launch ..." then the session loads.
Then I get:
"The session contains media that is not supported possibly due to a missing CODEC." "OK"
The session finishes loading and the ProRes video track is there but no video, but the video is fine on the h.264 track. I have another exact same session, but it has a dnx version of the video. I load it and it's fine. I go back to the previous session, and the ProRes version is fine.
I made a session that just had ProRes and I get the same errors.
I have found that when I quit ProTools I seem to get this error sequence almost every time, no matter what video format I have in the session. ( I just tried it with the dnx copy and got the same sequence of errors.) The sessions load but no video. I immediately close and re-open the session and everything is fine.
I've tried a few different sessions now. 3 different videos (different clients even). All the same thing. As long as PT is running I can change sessions and it's fine. The first time the Video Engine loads it gets the error and I have to close and re-open the session for the video to work.
I've also tried starting PT with a session that has no video, then loading a video into that session. I get "There was an error with the Video Engine" or something. It has to quit the video engine. It gets an error. Tries again. Sometimes the video loads fine, sometimes not. But if I then load another session with video it's fine.
If I go back to 12.4, everything works fine.
I've re-installed 12.5, trashed prefs. No difference.
Anybody Else?
Vince
Mac OS X 10.9.5, 32 Gigs RAM, BlackMagic DeckLink SDI 4K
Old 04-01-2016, 01:03 PM
Brandonx1 Brandonx1 is offline
Default Re: PT 12.5 Video Engine
Pro res works very well on my system. Both osx and Windows
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
Old 04-01-2016, 05:05 PM
gives's Avatar
gives gives is offline
Then I get:
Anybody Else?
Vince
I recently switched from H.264 after years of using it.
I would take a look a this list from Avid.
http://avid.force.com/pkb/articles/e...r-Pro-Tools-11
It says that H.264 (Performance may vary).. Not sure what that means, but have been using DNxHD (Preferred) or just an mp4 without issues. G
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS
Old 04-01-2016, 10:44 PM
EarHole EarHole is offline
This issue really needs to be fixed. It's caused my room to go down multiple times with no solution. Converting to Pro Res is a pain in the heat of battle with a room full of clients. It also makes archiving more copious.
I've worked on Pro Tools for about 20 years, day in, day out. My current system is fast and powerful but asking it to be rock solid on the video front like my previous rigs is a fleeting dream.
Editors are kicking out and posting video & revisions in mp4 and h.264 for mix files. It's a way of life for us these days.
Old 04-01-2016, 11:03 PM
Buccanears's Avatar
Buccanears Buccanears is offline
They can't simply "fix it". It's the nature of the format. H264 is a delivery format fit for the best high quality kitten videos on the interwebs.
It is not a format for post production.
https://randycoppinger.com/2012/06/1...nd-h264-video/
Q "where are your buccanears?"
A "on your buccanhead!"
IMDB
Old 04-02-2016, 01:15 AM
Mark Ziebarth Mark Ziebarth is offline
That's true. I tested with Pro Tools 11 the other day and H264 videos performed as well as dnxHD. They've been even less CPU consuming, what I didn't expect.
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate
Mac mini 2018 i5 64 GB RAM, RME Fireface, Pro Tools 2021, Euphonix MC Control
MacBook Air 2020 (M1) 16 GB RAM, 1 TB SSD, Zoom U-44 and Pro Tools Ultimate
Old 04-02-2016, 03:01 AM
Exactly
Brandon Howlett
Re-recording Mixer
S6 M10 24 fader
Old 04-02-2016, 08:16 AM
diamondschwin diamondschwin is offline
Have had decent experience with the new video engine. The new black magic drivers are still terrible so we are sticking to 10.4.x but those also had to be reinstalled after the 12.5 upgrade.
Glad they have moved the video engine up. I'm guessing that's in preparation for official support of the DNXio and DNXHR and 2k/4k
Max Holland
Producer / Re-Recording Mixer
Nashville / NYC
MKD Creative
Old 04-02-2016, 09:53 AM
VRS VRS is offline
Please don't get set off on an h.264 path. It's got nothing to do with h.264.
I always get clients to send me DNx or ProRes, or I convert to DNx. The session I imported just happened to have the original h.264 picture in it as well. I did a bunch of tests with various video codecs to see what was up. It doesn't matter which codec I use I get these errors.
I never edit with h.264.
I heard from a buddy of mine last night who's getting the same Video Engine errors. He emailed me to see if I had similar problems.
Vince
Old 04-02-2016, 12:31 PM
HDXSound HDXSound is offline
Dnxhd videos generate the same errors on my rig...
Protools 2019.12, HighSierra 10.13.6, 2x2.66 Ghz 6 Core intel Xeon, 24 Gb 1333 MHz DDR3
HTML code is On
'The Video Engine reported and error' message when trying to play any video zerothrills Pro Tools 12 10 02-28-2022 04:04 AM
video engine loftus Pro Tools 11 1 08-19-2015 02:15 PM
Video Engine not working.. crashing when i load in a video to PT11 sarahsherlock Pro Tools 11 5 08-16-2014 12:35 AM
PT 10HD with MXF Video wants Video Engine? rantanplan Pro Tools 10 2 06-05-2014 09:50 AM
Boot Screen "Not Recognized Video Hardware Connected", "video engine failed to init bcrichguitar macOS 3 04-01-2012 09:10 AM
