PT Hangs at DAE Loaded message
So I made the jump from PT LE with a 003 to a PT HD Native card with an OMNI. I've got a brand new PC with nothing installed except windows drivers and PT9.
When I start Pro Tools it hangs at the "DAE Loaded" message. I've tried lot of things, delete databases dae folder etc, nothing's worked. Any ideas would be much appreciated. I'm hoping there's not an incompatibility with my hardware. It did my best with the limited time I had to make sure the hardware would be okay. I'm a bit green when it comes to PT hardware incompatibilites as I've never had any issues with it regardless of what hardware I was using. Here's the Sandra report: SiSoftware Sandra Computer Model : Gigabyte X58A-UD5 Processor Model : Intel(R) Core(TM) i7 CPU 960 @ 3.20GHz Speed : 3.33GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 16 threads sharing Computer Mainboard : Gigabyte X58A-UD5 BIOS : Award (Phoenix) FD 02/01/2011 Bus(es) : X-Bus PCI PCIe IMB USB i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 12GB DIMM DDR3 Chipset Model : Giga-Byte X58 I/O Hub Front Side Bus Speed : 2x 2.4GHz (4.79GHz) Chipset Model : Giga-Byte Core Desktop (Bloomfield) UnCore Front Side Bus Speed : 2x 2.4GHz (4.79GHz) Total Memory : 12GB DIMM DDR3 Channels : 3 Memory Bus Speed : 2x 532MHz (1GHz) Memory Module(s) Memory Module : Corsair CM3X2G1333C9 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 5-34-10-5) Memory Module : Corsair CM3X2G1333C9 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 5-34-10-5) Memory Module : Corsair CM3X2G1333C9 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 5-34-10-5) Memory Module : Corsair CM3X2G1333C9 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 5-34-10-5) Memory Module : Corsair CM3X2G1333C9 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 5-34-10-5) Memory Module : Corsair CM3X2G1333C9 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 5-34-10-5) Video System Video Adapter : NVIDIA GeForce 8600 GT (32 SM4.0 1.1GHz, 256MB DDR3 1.4GHz 128-bit, PCIe 1.00 x16) Graphics Processor OpenCL Processor : NVIDIA GeForce 8600 GT (32SP 4C 1.19GHz, 256MB DDR3 1.4GHz 128-bit) Compute Shader Processor : NVIDIA GeForce 8600 GT (32SP 1.1GHz, 256MB DDR3 1.4GHz 128-bit) CUDA Processor : NVIDIA GeForce 8600 GT (32SP 4C 1.19GHz, 256MB DDR3 1.4GHz 128-bit) Storage Devices OCZ-VERTEX2 (115GB, SATA300, SSD) : 107GB (C:) Seagate ST32000641AS (2TB, SATA600, 3.5", 7200rpm) : 2TB (D:) Seagate ST32000641AS (2TB, SATA600, 3.5", 7200rpm) : 2TB (E:) WDC WD800JD-75MSA3 80GB (SATA300, 8MB Cache) : 75GB (F:) Seagate ST9250421ASG (250GB, USB/SATA, 2.5") : 233GB (H:) HL-DT-ST DVD+/-RW GSA-H73N (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (G:) Logical Storage Devices System Reserved : 100MB (NTFS) 01-Data (D:) : 2TB (NTFS) @ Seagate ST32000641AS (2TB, SATA600, 3.5", 7200rpm) 02-Samples (E:) : 2TB (NTFS) @ Seagate ST32000641AS (2TB, SATA600, 3.5", 7200rpm) 03-Audio (F:) : 75GB (NTFS) @ WDC WD800JD-75MSA3 80GB (SATA300, 8MB Cache) USB_250GB (H:) : 233GB (NTFS) @ Seagate ST9250421ASG (250GB, USB/SATA, 2.5") 00-Boot (C:) : 107GB (NTFS) @ OCZ-VERTEX2 (115GB, SATA300, SSD) Optical Drive (G:) : N/A @ HL-DT-ST DVD+/-RW GSA-H73N (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Giga-Byte LPC Interface Controller LPC Legacy Controller 1 : ITE IT8720F Disk Controller : Giga-Byte 4 port SATA IDE Controller Disk Controller : Giga-Byte 2 port SATA IDE Controller Disk Controller : Giga-Byte 88SE91A3 SATA-600 Controller Disk Controller : Giga-Byte JMB36X PCIE-to-SATAII/IDE RAID Controller Disk Controller : Giga-Byte JMB36X PCIE-to-SATAII/IDE RAID Controller USB Controller 1 : Giga-Byte USB UHCI Controller #4 USB Controller 2 : Giga-Byte USB UHCI Controller #5 USB Controller 3 : Giga-Byte USB UHCI Controller #6 USB Controller 4 : Giga-Byte USB EHCI Controller #2 USB Controller 5 : Giga-Byte USB UHCI Controller #1 USB Controller 6 : Giga-Byte USB UHCI Controller #2 USB Controller 7 : Giga-Byte USB UHCI Controller #3 USB Controller 8 : Giga-Byte USB EHCI Controller #1 SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Realtek PCIe GBE Family Controller (Ethernet, 100Mbps) Network Adapter : Realtek PCIe GBE Family Controller #2 Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1) Platform Compliance : x64 |
Re: PT Hangs at DAE Loaded message
Hmmm... have you downloaded the latest PACEDriver from iLok.com? What iLok USB key type do you have? Gen 1 or Gen 2.
Aaron Mulqueen - 001 HD Native |
Yes, I've got the latest versions of both the driver and client. iLok is generation 2.
Is Support License listed in Programs and Features>Control Panel?
Yes, it says "Licence Support" then "PACE Anti-Piracy, Inc Version 1.00.0000"
Ummm... you wouldn't happen to have Pro Tools 8.5.0 come with that HD Native system? What about a iLok USB key gen 1?
Thanks for your help. I've tried a clean build with 8.5 and I've now tried with gen 1 iLok.
ABT,
I have a very similar setup to yours (see my signature) except for the video card and have no issues. I really don't know whats wrong, but have you run the DigiTest and made sure your Native card is well seated? Beyond this, I would look at your video card. I think I read somewhere on the DUC that Nvidea card users should try only installing the drivers and none of the other little apps that come with the card. Hope this helps, Greg
Intel i7 3930K, Gigabyte GA-X79-UP4 (rev 1.0), 32 GB Corsair Vengeance 1600 ram, EVGA Nvidea GT 720 TI video card, a Samsung 850 Pro (256 GB) OS drive, 2 Samsung 850 Pro's (512 GB) in externally mounted drive bays for session and sample storage, Win 10 Pro, PT Ultimate (Native)2019.10, HD Omni, HD I/O 16x16 . |
Pro Tools HD System Requirements: Solid State Drives (SSDs) have not been tested or qualified for use with Pro Tools, either as system or audio drives.
I've just done a clean Win7 install on a SATA drive. Same problem I'm afraid.
DAE Loaded hangs | dmichael | Windows | 0 | 07-13-2011 10:54 AM |
New Dell Laptop hangs on "DAE Loaded" PT8 Vista | Neil Miller | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 02-16-2009 03:30 PM |
PTLE7.4CS4 w/ 002 rack hangs on DAE Loaded in Vista | Scottbanger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 09-18-2008 10:04 AM |
PT hangs on DAE Loaded | g00db33r | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 05-29-2008 12:52 AM |
PT hangs on startup at DAE loaded | justmull1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-20-2007 06:48 PM |
