Old 11-11-2005, 12:26 PM
Tex Tiles Tex Tiles is offline
Default 24 bit throughput on 16 bit PT3 nubus?
Hi, I have a PT3 nubus system with an 888 and a Lexicon Nuverb card running as an effects proccesor in my analog 2" and PTle studio. I seem to recall that the 888 and the 5.1 software would throughput 24 bit audio via digital in, just not record it to disc. Is this correct?
As I am using it as an effects proccesor this would suit me fine. I think the Nuverb card is 16 bit only though.
thanks in advance for your knowledgeable reply.
Tex
Old 11-15-2005, 01:10 PM
jeffro's Avatar
jeffro jeffro is offline
Default Re: 24 bit throughput on 16 bit PT3 nubus?
PTIII NuBus is limited to 16-bit.
Answerbase 1625
linkedin
Old 11-16-2005, 01:22 PM
thank you
Old 12-01-2005, 12:12 PM
Diginerd Diginerd is offline
You got confused with PTIII on PCI, which does support 24bit I/O, just not to disk.
http://www.sgnr.net
HTML code is On
S/PDIF Maximun Sample Rate Throughput? RyLo Callahan General Discussion 1 08-28-2008 05:38 PM
192 I/O spdif Max Sample Rate throughput RyLo Callahan Pro Tools TDM Systems (Mac) 3 08-28-2008 05:35 PM
Throughput problems and weird pan/volume prob Scott Goldberg Pro Tools TDM Systems (Mac) 1 07-23-2006 02:59 PM
No throughput on armed tracks while playback? kennylovrin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 04-20-2006 04:09 AM
PCI load / SCSI throughput 2 bit Storage Subsystems 1 08-11-1999 05:28 PM
