Large delay/latency when using hardware inserts on Omni
I get a lagre delay/latency when I use my Cl1b as a hardware insert in Pro Tools Ultimate. Is this normal behaviour? I'm planing on getting another compressor Retro 176 befor christmas. What happens with the latency in PT if I connect another compressor. Will I get 2x the latency or will it stay the same? |
Re: Large delay/latency when using hardware inserts on Omni
How much latency? HDN or HDX? Going out and back with an analog insert should be fairly short(buffer setting plus conversion time to analog and back)
What interface? What is your IO buffer size? What is the latency you measure? They should agree? ... allow 2X for output and input.
Another analog compressor used in a separate hardware insert, or physically chained with this one is not going to increase the latency... unless you chain effects back through Pro Tools and out as another hardware insert again (uh don’t do that). |
Hi, I get 69 samples delay with my CL-1B Used as an hardware insert using matching inputs and outputs? otherwise delay comp doesn't work. this is with a 256 buffer on PT10 HD Chris
Are you trying to track with hardware inserts? That may be hoping for too much I track with hardware comps and/or EQ's, but they are in-line(between the preamps and the interface) so they don't incur any additional latency. While mixing, I prefer to stay in the box(but latency should not be an issue during mix as long as ADC is working).
HDN. I get over 2000 samples delay.
No. I connect one of the DB25 outputs on my Omni into my CL1b wich again goes back into the corresponding input line on Omni. I then select a I/O insert and get over 2000 samples delay on that channel.
I too do this 99.9% of the time. I just wanted to compare my hardware CL1b to my Softube Cl1b in a mixing situation. |
hardware inserts and delay compensation PT8 | PointStudios | macOS | 0 | 10-09-2014 04:23 AM |
how to get 4 x hardware inserts with AVID OMNI / PT HD | outoftune | Pro Tools HDX & HD Native Systems (Mac) | 7 | 04-04-2014 08:53 AM |
Delay compensation with hardware inserts | d.f. | Pro Tools TDM Systems (Mac) | 18 | 03-10-2009 11:57 PM |
delay on hardware inserts | georgedk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-18-2004 03:42 AM |
latency on hardware inserts | vtone | Tips & Tricks | 4 | 10-22-2000 05:37 AM |
