Old 11-20-2015, 02:19 AM
juancarlosmusic
Guest
Posts: n/a
Default Eleven Rack & Eleven MKII
this week I bought eleven rack and just see who have taken "Eleven MKII".
I have the Eleven plugin, the upgrade would be $ 50 plugin, and the Eleven Rack cost me $ 500.
Forums said that the plugin now has what version rack.
So you have advantages of having spent $ 500? consider yourself to have some advantage in rack, or return it and advise me to buy the plugin version?
My current system is "Pro Tools 12.3 digi003".
Thank you!
Old 11-20-2015, 06:12 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: Eleven Rack & Eleven MKII
Whether keeping the Eleven Rack is worth it really depends on your needs.
As far as amps, Eleven MKII now has all of the amps that are in the Eleven Rack with the expansion pack.
As for effects, all of the Eleven effects are available as a plugin as well, but they are not part of Eleven MKII. Therefore, you can not create presets with effects and save them like you can with the Eleven rack. For instance, you would have to save your favorite reverb setting separately, put Eleven MKII on a track, call up your preset, add the reverb plug, call up the reverb preset....
There is also latency. Depending on your system, you may have lower latency using the Rack.
Then there is always practice and live use. The Eleven rack is great for practicing since you don't have to fire up your computer. And since there is no stand alone app for Eleven MKII, you will always need to fire up Pro Tools just to use it.
So, again, it really depends on how you are going to use the rack and the plug-in. I personally like having both. I like having the effects stored with my presets, so I still use the Rack for some tracking, but I also use MKII for simple guitar parts where I don't have much on the track other than the amp and some verb.
Will
System Details
Old 11-20-2015, 07:38 AM
Shatzer Shatzer is offline
I really wished Avid would have put everything in one GUI similar to the eleven editor. Having a bunch of stompbox effect plugins is a bit of a mess, and would make sense to pair it with the Eleven plugin.
Old 11-20-2015, 08:34 AM
junkgear's Avatar
Agreed
Will
System Details
Old 11-20-2015, 10:17 PM
It's common knowledge that dedicated hardware, whether digital or analog is better than computers. Interfacing in the first instance is superior. Sound quality is 'generally' better. And regarding the Eleven Rack specifically, it's a hardware accelerator (standalone). It's a live tool and creative tool for those purposes. Keep it, unplug it from your computer and play. Simply record the audio and be done. IMNSHO.
Aaron Mulqueen - 001 HD Native
Old 11-22-2015, 08:40 AM
juancarlosmusic
Guest
Posts: n/a
I'll finally get to "Eleven Rack" by the advantages with respect to the plugin version. Do you know if Avid will continue to support the Eleven Rack, including new "expansion pack 2"?
Thank you.
Old 11-23-2015, 04:40 PM
zedhed's Avatar
zedhed zedhed is offline
Thank you.
It is highly unlikely anything new is going to happen with the 11R. By all appearances it's a dead duck to Avid.
Having said that, it's a great unit as it is; I have two of them, One for studio and other for live use.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Eleven Rack and Cubase Eleven Rig L/R input NOT WORKING !!! quebecguitare Eleven Rack 1 09-01-2015 11:40 PM
Eleven Rack / Avid is not producing anymore Eleven Racks is that true or false? Rongpat Eleven Rack 8 02-11-2014 07:42 AM
Some experimental tracks using Eleven rack and Eleven RTAS kittybite Eleven Rack 4 06-18-2013 12:18 AM
Eleven Rack window responds to changes on Eleven Rack, unable to record. pine Eleven Rack 6 08-02-2012 07:50 PM
Eleven Rack and Eleven Rack control window not matching 11R Newbie Eleven Rack 3 04-18-2012 06:07 PM
