I have a macbook pro 2.6 ghz i5 8 gigs of ram
running Pro Tools 11.3.1 I try opening my existing sessions and pro tools stops responding I try a new session and it stops responding I have tried taking all plugins off my older sessions doesn't help I have absolutely no clue what to do, maybe there is a preference that can be deleted or maybe a folder that needs deleting I have also repaired my disk as well as the permissions I'm stuck, if you can help me out that would be great thank you |
Which version of Mac OS X are you using? Have you moved all third party plug-ins from /Library/Application Support/Avid/Audio/Plug-Ins to /Library/Application Support/Avid/Audio/Plug-Ins (Unused)? Have you tried another OS X user account?
I am running OS X 10.10.4 Yosemite
It does give me an option to be put in unused but I thought that then the plugin would not work |
This is true. If a plug-in is in the unused folder, it is not available for use. Given that you are having problems doing the basics, it might be worth moving all non-Avid plug-ins into the unused folder and seeing if you are then able to create a new session without Pro Tools going into a non-responsive state.
It may also be worth trying this trick; hold the SHIFT key while you open a session. That command makes all plugins inactive. USUALLY, if a plugin is the issue, this will allow the session to open, and then you know its plugin-related(helps a bit with troubleshooting)
Gigabyte X79/intel i7 3930K, 32GB RAM, Presonus Studio 1810C https://www.facebook.com/search/top/...0sound%20works I started in this business with nothing..........and I have most of it left ![]() BTW, my name is Dave, but most people call me.........................Dave |
Unfortunately I am still having problems its like pro tools picks and chooses, i'll open the session and most of the time it opens and right away stops responding, sometimes I can get maybe 5 minutes before it stops responding 1 time yesterday I got about 30-45 minutes to use it before it stopped responding, I did disable the plugins and it made no difference it just doesn't seem to have a rhyme or reason I can't pick up a pattern like if I hit record, or use the faders or open other windows, it doesn't seem to matter
Someone had mentioned trying a new account on the mac and I did an still the exact same problem of the session not responding either immediately or 5-10 seconds in
Alt Tab doesn't work when Pro Tools is open | weezerboy | Windows | 18 | 02-23-2018 05:39 PM |
Bought Pro Tools 11(academic), given pro tools 12 licence, doesn't work! | TimCollins1311 | Pro Tools 11 | 2 | 03-17-2015 09:52 PM |
Mackie MCU + XT midi drop out in Pro Tools HUI errors controller stop responding | Tony_Nailz | MIDI | 5 | 02-23-2015 07:58 PM |
Spacebar doesn't work as start/stop with plugin open | Downtown_BE | macOS | 6 | 11-05-2014 06:19 PM |
Pro tools doesn't know when to stop! | svenhardini | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 10-05-2009 11:14 AM |
