how to use ad/da with 002 and tc electronics
I want to use my tc electronics m one xl as the ad/da with my pt9. I currently use the m1xl as my ad converter. I now want to monitor through the m1xl da conversion, how do I achieve this? I hooked up my Genelecs through xlrs from the TC thinking I would set the output in pt i/o to spdif and set audio out on TC to digital. Is this correct? Thank you in advance for any help.
Also, the masterfader in the song, which I always use, has the output set to spdif. Shouldn't this get me signal from the d/a i.e. TC?
PT9-002r-Mac Mini Duo Core 1.83-2gb-Neve-API-Urei-Neumann-ADK-AT-Waves Musician 2, Waves Morphoder, Etc..... Last edited by yachty; 11-08-2011 at 07:19 AM. Reason: update |
Re: how to use ad/da with 002 and tc electronics
When I record I set input on the M one xl to analog and go spdif into pt9 at 24/48k.
PT9-002r-Mac Mini Duo Core 1.83-2gb-Neve-API-Urei-Neumann-ADK-AT-Waves Musician 2, Waves Morphoder, Etc..... |
Surely someone has a suggestion, I appreciate the help.
My suggestion is; don't do this. The M-One XL is a great reverb/effect unit. But it was never designed to do what you are attempting. Use a D>A converter that is designed to do this and it will all work dandy. If you still feel the need, then remove any connections and run only a single SPDIF cable(a real SPDIF cable, not some old RCA cable from that cassette deck in the closet) from the 002 SPDIF out to the TC SPDIF in. Set(in the utility menu IIRC) the TC to digital input, put the unit in bypass(so you don't get reverb on the mix) and connect the XLR outputs to your powered speakers. Keep in mind that you may have no volume control with this setup(something a D>A converter would have). I ran the SPDIF out of my 002(now 003) to the SPDIF input of my Presonus Central Station, which worked fine, so that might also be a consideration(the Central Station offers a lot more functionality as well and I wouldn't give mine up).
Thanks Albee, I have pro grade cables, and research shows the chip in the TC to be high quality. Still ordering a separate ad/da but for now I need to hear what I have already.........
TC Electronics | YYR123 | General Discussion | 0 | 06-04-2013 05:53 AM |
why tc electronics vst are not recognized on pt 9? | papitopinillo | Pro Tools 9 | 8 | 09-10-2011 06:10 PM |
TC electronics P2 | formfunction | Post - Surround - Video | 0 | 10-17-2009 08:23 AM |
TC Electronics VoiceWorks | Jon Martin | VENUE Live Sound Systems | 1 | 06-30-2007 03:41 PM |
TC Electronics | theblasters | Pro Tools TDM Systems (Mac) | 1 | 05-08-2006 04:10 PM |
