Old 12-18-2006, 11:11 PM
pikapikapi pikapikapi is offline
Default midi outputs? aux track or instrument track?
What is the difference between an aux track and an instrument track? I've seen some tutorials using aux and some tutorials using instrument tracks. Some say to use aux track for only reverb and delay effects. I want to use sampletank 2 as my virtual instrument so which output do i use?
Old 12-19-2006, 12:17 AM
Default Re: midi outputs? aux track or instrument track?
Some basic usages, Send & Return AUX, External MIDI Device MIDI/AUX, Virtual Instrument Instrument track.
filosofem
Aaron Mulqueen - 001 HD Native
Old 12-19-2006, 12:19 AM
what about samplers like sonik synth and sampletank?
Old 12-19-2006, 12:38 AM
Those would fall under the realm of Virtual (Computer-Based) Instruments, wouldn't you think?
filosofem
Old 12-19-2006, 02:12 AM
in the protools method 1 dvd, the guy uses an aux track as an output to his midi track when he was using sampletank. in another dvd tutorial a guy uses an instrument track, i'm just confused. so both ways work?
Old 12-19-2006, 02:28 AM
polf polf is offline
hello,
instrument tracks were only introduced recently to Pro Tools LE in version 7 (i think) and before this we had use a midi/aux configuration.
So both ways work but the instrument track way is much easier - which is why it was introduced.
cheers
steve
copy instrument track to midi track trev1238 Pro Tools 9 5 02-04-2012 01:16 AM
Assigning Kontakt outputs to Instrument track in PT sky88dd Virtual Instruments 0 09-27-2007 03:34 PM
Difference between Midi Track & Instrument Track better? paul Neathery 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 07-16-2007 04:03 PM
Mapping MIDI Track To Instrument Track Delta Dreams 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-08-2007 11:26 AM
using instrument track vs. midi+auxilary track digimike 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-02-2006 09:21 AM
