Old 11-17-2006, 09:03 AM
catalin rasvan catalin rasvan is offline
Default Behringer BCF2000
Please , I have a questin : Is it possible to controll automation plugins efects in protools
like eq or compress parameters in Protools M-Powered with Behringer BCF2000 ?
I really apreciate your anwer,
catalin
Old 11-18-2006, 09:52 PM
Skyflash Skyflash is offline
Default Re: Behringer BCF2000
I have a BCF2000 and I have yet to find a way to control plugin parameters.
It's been a little while since I used it with PT. I know the templates supplied
by Behringer(D/L on the site and in the manual)indicate that holding down
two keys(forgot wich ones sorry) are supposed to enable control of plugins
but it does not work. After an hour or so I just gave up....
I'm afraid tha true plugin functinoality only works with the 002 and and
and the Project Mix I/O.....
I'll try this again in a couple days.
2006 'Blackbook' Core Duo 2.0 ghz.
2 gig OWC RAM
10.5.8
PT Mpowered 8.04, Logic 9.1.1
Waves SSL,Omnisphere,Korg Legacy Digital
Absynth 4, EZ Drummer
Project Mix I/O w/ Black Lion Mod
Axiom 61,25, Korg Nano Pad
Old 11-20-2006, 02:35 PM
Hi Skiflash.
First of all ,thank you for answer.
I have an Edirol PCR 80 and I succeed making to work automation plagins in protools M-P.
It is a little trick :
First please go to digidesign.com and donlowd Legacy MIDI Controllers PT7 directory.
I think is a rar fille. In it you'l find a .dll named cs 10 dll. Copy this dll in directory from Program files - common filles-digidesign-controllers.
After that you must asign some control change in yours fader in your bfc 2000.
Heare I send you a list of this control changes :
Global channel 16
Faders C1-9 = cc's 64-71 (track volume controls)
Buttons C32-39 = cc's 0-7, (mute or whatever buttons)
Button C40 = cc 8, (mode switch)
Button C27 = cc 19 (rewind)
Button C28 = cc 21 (stop)
Button C29 = cc 23 (record)
Button C30 = cc 22 (play)
Button C31 = cc 20 (fast forward)
Knobs B10,11,12 = cc's 72,73,74 (sends 3,4,5)
Knobs B14,15,16 = cc's 75,76,77 (sends 1,2, pan)
Pitch bend A22 = cc 9 (shift)
Mod wheel A32 = cc 14 (option)
Knob B13 = cc 15 (control)
Knob B14 = cc 15 (command)
Joystick B18 = cc 29 (right)
Joystick B19 = cc 28 (left)
Joystick B20 = cc 26 (up)
Joystick B21 = cc 27 (down)
You must asign to one fader control change number 27 (IT IS verry important!!!)
after that you mast asign the folorwing control change to yiour fader:
cc 72,cc73,cc74,cc75,cc76,cc77.each other them on the other fader.
First you have to move the fader wich have on it 27 CC.
Afther that, when you will move any of the two faders 72 or 77 you will see that you will succeed what you want to make it.
Enjoy and good luck.
Catalin
Old 11-20-2006, 03:21 PM
spkguitar's Avatar
Catalin, that method is not required for the BCF because the BCF has HUI emulation.
Old 11-21-2006, 05:00 AM
Hi Spkguitar,
I don't have BFC 2000,so I beleved that it can be manually asigned like ordinary midicontroller.
Sorry ! However, You are sure it will not be manually asigned ?
Old 11-21-2006, 05:18 AM
spkguitar's Avatar
Read all about it on the Behringer website.
Behringer BCF2000 and PT 9? 2sonic macOS 2 08-05-2011 09:26 PM
Behringer BCF2000 songman0412 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-29-2006 05:56 PM
behringer bcf2000. what do you think fhinspectit Pro Tools M-Powered (Win) 11 09-03-2006 06:30 AM
Anyone using the Behringer BCF2000? JCBigler 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-31-2005 11:43 AM
Behringer BCF2000 gustavof 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-28-2004 05:44 PM
