#21
Re: S3 AVB not all Macs compatible
Thanks for the clear answer...
I will try the PCIe Route... Has anyone a tip for a Etherenet PCIe Card with AVB working on Mac OSX? Someone mentioned the Presto Gigabit PCIe Pro, but on the Product Site from Sonnet, there is no hint, that this card support AVB... Thx for help Last edited by TrackerLe; 09-02-2016 at 11:17 PM. |
#22
I just found this thread after purchasing a previously owned S3 and finding that my Mac Pro vintage 2010 is not AVB enabled. If I purchase this Motu AVB switch, will that make my S3 usable with my Mac Pro? Thanks, Paul |
#23
Just to clarify – you can use an S3 with a non-AVB Mac, you just won't be able to use it as an audio interface. Buying an AVB switch will not make a difference to the latter case.
https://lukehoward.com/ |
#24
Thanks for the feedback. So, this limits the S3 to the faders and other controls but the I/O is not functional, correct? Which Mac Pro began AVB capability?
#25
You got it. That's how I use mine. If you're using HDX/HD Native, the AVB I/O isn't much use anyway, because you can't use it at the same time as the HD engine. (I think you can use the S3 independently as a monitor controller, don't quote me on that – but in any case, you're getting an extra A/D D/A round-trip which I'd want to avoid.)
#26
#27
With the trashcan. If the Mac has Thunderbolt, then it supports AVB (irrespective of whether it has on-board Ethernet).
#28
Q: Can I use MOTU AVB interfaces on my older Mac that is running OS 10.6 or 10.7 and does not have Thunderbolt ports? A: Yes (although this is not officially supported. Official support requires 10.8 or later.) USB can be used to connect a Mac to the AVB system for up to 64 channels of input and 64 channels of output (at 44.1 or 48 kHz). Because MOTU AVB interfaces are USB audio class compliant, no driver installation is necessary under Mac OS X 10.6 or 10.7. As soon as you plug in the USB cable and switch on the interface, the Mac "sees" all the audio channels and makes them available to your DAW or other Mac audio software. Web app control (for access to device settings, the on-board mixer, etc.) can be accomplished through a direct Ethernet connection from the network port on the interface to the Mac's network port. The Mac accesses the web app (which is being served directly from the interface itself) through the network connection. ---------------------------------------------- Would this make an older non Thunderbolt Mac Pro AVB capable? Thanks, Paul |
#29
001 compatible with new macs? | Thetics | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-06-2006 11:14 PM |
Digi, are new Macs compatible yes or no ?!? | Mark Haliday | Pro Tools TDM Systems (Mac) | 3 | 04-17-2003 07:19 AM |
OS9-compatible brand new Macs still available | MGalway | Pro Tools TDM Systems (Mac) | 4 | 03-12-2003 02:46 PM |
Are the DP867 macs compatible with PT HD? | GrooveEntertainment | Pro Tools TDM Systems (Mac) | 1 | 10-04-2002 11:21 AM |
NEW MACS COMPATIBLE !!!! | Norbert, Peak Sounds, Inc. | Pro Tools TDM Systems (Mac) | 1 | 08-31-2002 05:48 PM |
