Re: S3 AVB not all Macs compatible
Wow, this is really surprising. My understanding has always been that only Macs with Thunderbolt port(s) have AVB support. So, you're able to stream AVB audio from S3L-X to Pro Tools via Ethernet port on that Mac Pro 3,1?
Kyle Splittgerber Senior Principal Product Designer Avid Berkeley, CA |
AVB on Mac is handled automatically via Core Audio. There are no drivers.
Right but what about Windows based venue systems. How does avb work on windows venue but not pro tools we down systems?
Brandon Howlett Vibe Audio Post, Inc. Re-recording Mixer Custom Build CPU, HDX 1, Omni, 192 I/O Digital S6 M10 24 fader Satellite Mac Pro, HDNative, 192 I/0 Black Magic HD Extreme |
The AVB card in the engine is not just an Ethernet port. It's highly custom and doing a lot of tasks. So, it's a bit of apples and oranges. There are some Windows AVB systems out there, so maybe streaming to/from S3/S3L-X AVB would work? But, we don't currently test it. The main reason is that AVB on Win is not ubiquitous like Mac. Any Mac with a TB port supports AVB. You can't make a statement like that for Windows machines (at least not yet). Also, I don't know of any AVB-enabled laptops and obviously laptops are ideal for recording from a Venue system. Hence, the focus on Mac support.
#16
Hi Kyle,
I have my S3 connected to the switch of my router. If Eucon is working correctly etc and everything is humming along nicely, should I see the AVB I/O in audio midi setup? Because I am not at the moment. If the answer is "you need to connect directly to the computer" then, can I see other workstations on my network if I'm using the second ethernet port of my nMPro2013? Just trying to clarify what I need to do to configure AVB correctly. **edit - Just tried direct and of course it works great! (haven't ventured to the other workstation level yet.) Regards, Matt
Matt McKenzie-Smith mattrixx.net SourceConnect - mattrixx AVID Collab user - mattrixx MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01 Last edited by mattrixx; 06-17-2016 at 12:35 AM. Reason: follow up |
#17
#18
Cool, that makes sense. Thanks Kyle
Matt McKenzie-Smith mattrixx.net SourceConnect - mattrixx AVID Collab user - mattrixx MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01 |
#19
Does that mean, that AVB on the S3L works with the mac pro 3.1-5.1...
and the identical S3 doesn´t? I have a 12 core 5.1... Is there any workaround to get the avb interface working on this machine... |
#20
No. S3L, nor S3, nor any AVB device will work on those older Mac Pro machines because they don't support AVB. You may be able to find a 3P AVB PCIe solution, but it's not something we support so can't say what results you'd have.
001 compatible with new macs? | Thetics | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-06-2006 11:14 PM |
Digi, are new Macs compatible yes or no ?!? | Mark Haliday | Pro Tools TDM Systems (Mac) | 3 | 04-17-2003 07:19 AM |
OS9-compatible brand new Macs still available | MGalway | Pro Tools TDM Systems (Mac) | 4 | 03-12-2003 02:46 PM |
Are the DP867 macs compatible with PT HD? | GrooveEntertainment | Pro Tools TDM Systems (Mac) | 1 | 10-04-2002 11:21 AM |
NEW MACS COMPATIBLE !!!! | Norbert, Peak Sounds, Inc. | Pro Tools TDM Systems (Mac) | 1 | 08-31-2002 05:48 PM |
