#21
Re: $2100 to spend on new pro tools computer...
Just to jump in here, I do have an i7 iMac, with a projectMix I/O and it runs flawlessly with 2 drives chained in front of the interface. 1 is a Glyph and the other is either an OWC Mini stack or a Lacie D2. The Glyph is the last link between the iMac and everything else, it's FW400 to FW800 (Glyph to iMAC), FW400 to FW400 (Lacie/OWC to Glyph) and FW400 to FW800 (PM I/O to Lacie/OWC). All the drives have their own power.
I used a similar configuration with the last generation core duo 2 iMac as well, without any issues.
Pro Tools, Studio One Pro 2022 Mac Studio M1 Max 64GB-1TB NVME OWC Thunderbay Mini (4TB SSD) OWC Express 4M2 (4 X 2TB) Interface: Presonus Quantum Presonus Faderport & Faderport 8 Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128 BM5A, KRK VXT4, Equator D5 2020 Macbook Pro 16GB RAM, 512GB SSD Audio(mobile rig) |
#22
what kills me is it worked perfectly on my little macbook pro, so i'm scratching my head why the imac firewire isn't acting the same.
Mac Pro 5,1 2.4GHz 8-Core 16GB RAM High Sierra | Focusrite Scarlett 6i6 Mk2 | Pro Tools 2020 | Studio One 4 |
#23
All of my drives are bus powered. I have not had an issue with any of them on either my MacBook, MacBook Pro, or Mac Pro.
| Logic Pro 9 | Reason 6.5 | Pro Tools 10 | MOTU UltraLite mk3 | RME ADI-2 | Summit Audio 2BA-221 x 2 | MOTU 8pre x 2 | | Mac Pro (4,1) 2.26gHz Xeon x 2 16gB OS X 10.7.4 | Macbook Pro (8,2) 2.2gHz i7 Quad 16gB OS X 10.7.4 | |
#24
It's possible that the macbook has more power on it's firewire bus than the imac. That would actually make sense from a design standpoint, it's much more likely that someone's going to run a firewire peripheral without an external power supply from a macbook than a massive 27" imac.
- John If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound? |
#25
On the tech specs on the Apple site, the iMac port is listed at 7 watts, but no wattage is given for the MacBook Pro. Although I found some docs for an older MacBook Pro, also listed as 7 watts. Doesn't confirm or deny anything. Though 7 watts does sound rather low. Considering the power supply for the G-Drive Mini is 12 watts. I'm sure when that thing is spinning it's arse off, recording and playing back audio, it's using all the power it can get. So, in addition to ordering the power supply for my G-Drive Mini, I also ordered an OWC 1TB quad interface external drive. The G-Drive is cute and portable and all, but maybe I need a more robust drive in between the iMac and the ProFire. Either way, I needed a 1TB backup drive, so it's not like it was a waste of money. I don't wanna give up on the iMac, I like it a lot.
#26
#27
I can understand liking the iMac. I for one like the Mac Pro since I can have my audio drive as an internal SATA drive. You can literally install or swap internal hard drives (after shutting down) in about 30 seconds. This frees up my entire firewire bus for just the audio interface with nothing to conflict with it.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
#28
#29
Understandable. I have a 30" Dell at 2560x1600 on my Mac Pro. It is lovely.
#30
Seems to me imacs like imac/interface/hardrive
I would for sure try this for sure before jumping ship on the imac. |
Core i3-2100/H61/4GB/1TB SuperCombo!!! | Tamadrummer30 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-24-2011 01:29 PM |
Compaq Presario 2100 and 002R | BaCKhead | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-06-2004 01:05 AM |
pc 2100 or 2700? | Doug Paluch | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-19-2002 03:50 AM |
How do I overclock my XP 2100+ | Captain_Pants | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 08-04-2002 12:58 AM |
How should I spend my next $440-$500? | badperson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 02-07-2002 12:05 AM |
