Old 12-05-2018, 07:12 PM
Molonlabe23 Molonlabe23 is offline
Default Eleven Rack and POD X3
Just got my 11R the other day and was surprised to find that my POD X3 works amazingly well as a controller and didn't have to program anything. The tuner button brings up the tuner, the bank arrows changes banks, the patch buttons select 1 thru 4 of each bank and the delay, dist and mod turn on and off the effects. The wah and volume both work too.
The only thing I can't figure is how to assign something different to Tone 2 button which right now switches between Guitar and L&R inputs.
I searched through both manuals and can't figure out how to change assignments of a button. Worst case Ill deal with it as I'm just happy that it works. If anyone knows how to change the assignment I would appreciate it.
One last thing I have a old Digi02 that the FireWire doesn't work any more, is there a way I could make use of it again by connecting the spdif connector to the Eleven rack a d use it to add more inputs to the Eleven rack?
Thanks
Old 12-05-2018, 07:38 PM
Default Re: Eleven Rack and POD X3
Using the 002, why yes you can.
http://archive.digidesign.com/suppor...d_with_002.pdf
Read the section "Using Digi 002 as a Stand-Alone Mixer"
That will let you do what you want but the 002 is old and clunky and not that great sounding.
Presumably you mean the Pod X3 Live... you need to read about it's MIDI CC programming capabilities, all the Eleven Rack MIDI capabilities are described in the Eleven Rack User Guide. I'm pretty sure the Pod X3 Live Pilot Guide/Advanced Manual tells you all there is about the CC out capabilities of the device. It is not uncommon to use a MIDI sniffer running on a computer to sniff what MIDI commands are being sent and do slow careful debugging to sort out what is going on with MIDI controllers.
Old 12-05-2018, 08:06 PM
Thank you, after reading that it looks like I would only be able to use two channels from the spdif connector and wouldn't be worth the real estate it would take up. Thank you again for the info.
Old 12-05-2018, 08:11 PM
Remember S/PDIF is two channel by definition, can never support more.
Check out the Eleven Rack Presets Matched for Eleven plugins by Pro Tools Expert! Justin1524 Eleven Rack 0 11-27-2015 02:53 PM
Eleven Rack and Cubase Eleven Rig L/R input NOT WORKING !!! quebecguitare Eleven Rack 1 09-01-2015 11:40 PM
Eleven Rack / Avid is not producing anymore Eleven Racks is that true or false? Rongpat Eleven Rack 8 02-11-2014 07:42 AM
Eleven Rack window responds to changes on Eleven Rack, unable to record. pine Eleven Rack 6 08-02-2012 07:50 PM
Eleven Rack and Eleven Rack control window not matching 11R Newbie Eleven Rack 3 04-18-2012 06:07 PM
