Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 06-24-2018, 04:04 PM
LukeHoward LukeHoward is offline
Default iOS monitor control for MTRX
Frustrated by not being able to select sources and outputs for my MTRX via the Dock, I wrote an iOS app. It’s free, completely unsupported by myself, Avid or DAD, and you can find it here:
https://itunes.apple.com/us/app/mom/id1387772808?mt=8
NB: DADman 5.2 or higher required. Configure it as you would a hardware MOM.
https://lukehoward.com/
Old 06-24-2018, 06:23 PM
teedeecee teedeecee is offline
Default Re: iOS monitor control for MTRX
Congrats Luke on seeing a problem you could build a solution for, and building it!. Wishing we had some DAD gear.
Old 06-24-2018, 07:10 PM
BScout BScout is offline
Great work. Playing with it now.
(BTW, I probably would not have named the app that as DAD could have an issue and any other name would have worked. There's a chance your app will get booted from the store because of that.)
Old 06-24-2018, 09:05 PM
True, I’m totally happy to change the name if they’ve an issue. I’m sure I can think of another punny acronym! Maybe Monitor Utility Module
Old 06-24-2018, 10:45 PM
Bad puns make sessions easier and more fun.
Old 06-24-2018, 11:43 PM
Dig!
Old 06-25-2018, 12:32 AM
its2loud its2loud is offline
Nice work!
Avid should license it from you and port it into the Control App.
Old 06-25-2018, 01:25 AM
Originally Posted by its2loud View Post
Nice work!
I believe that Pro Tools | Control will support monitor source and output selection eventually (via EuCon, which DADman supports). It does already support volume and cut.
The MOM hardware or software remotes are complementary as you can have many of them (each with multiple layers), assigned to different sources and outputs.
Old 06-25-2018, 03:04 AM
A few tips:
  • You can set custom names for sources and outputs in Settings
  • The app works most reliably when the iOS device and DADman are on the same subnet, however there is some support for separate subnets; this requires a DADman host to be specified in settings
  • Swipe left to advance layers (unfortunately due to a protocol limitation it’s not possible to swipe right)
  • Again owing to a limitation in the protocol spoken by DADman, it’s not possible to see gains below -40dB. They can be set, however.
  • Talkback switch is latching if pressed briefly, momentary if not
  • You can rename the MOM device and/or change its device ID from with DADman.
  • DADman can sometimes take a moment to reconnect, particularly if the app has been offline for some time. You can prevent your device from going to sleep when MOM is active by enabling Disable Idle Timer in its settings.
Old 06-25-2018, 04:31 AM
Pete Gates Pete Gates is offline
Nice job!
I have a question, what is the protocol used by DADMan? Is it Eucon or their own thing? Is it published anywhere?
Cheers,
Pete
ps been listening to your music this morning, enjoying it very much
Does the Monitor Control Room knob on the Artist Control do anything? Focuret Artist Series 34 01-29-2024 03:14 PM
PT Dock / MTRX Control remotedude Avid S1, S3, Dock and Control App 11 12-16-2018 07:40 PM
Monitor Knob - Cut Assignment like XMON but now for MTRX innenhofstudios Avid S4/S6 10 05-17-2018 03:23 AM
MTRX antonis Post - Surround - Video 2 10-26-2016 12:31 AM
Artict Control Monitor/Control Room Knob & HD Omni DAWgEAR Artist Series 4 07-07-2014 01:56 PM
