  #21
Old 01-25-2019, 05:50 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: True or False or
Originally Posted by cwsand View Post
Yep, analog distortion is great - digital clipping? Not so much!
Originally Posted by Sardi View Post
Only if desired.
Well that's true of all recording decisions!!
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (3)
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
  #22
Old 01-25-2019, 05:56 PM
cwsand's Avatar
Originally Posted by amagras View Post
What is digital clipping?
How do you create it?
Digital distortion - usually not a desirable sound.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (3)
Slate Digital VRS8
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
  #23
Old 02-07-2019, 08:05 AM
Sugarnutz Sugarnutz is offline
Both are not only false, they're outright lies! No matter the medium or device you record with, basic fundamental recording skills are mandatory.
Overloading an operational amplifier is a recipe for disaster, the most you can do to correct it after the fact is run it through a transformer to round off the square waves you just created and while that may be a desired effect in some circles, it won't be in all of them.
Proximity effect is a result of making a microphone element directional by venting sound to the rear of a diaphragm and canceling the sound from the rear by making it out of phase with the front. The problem is it only works at shorter wavelengths, AKA higher frequencies, lower frequencies are reinforced making them louder. A trick I learned a long time ago is to not use a cardioid microphone to close mic an instrument, use an omnidirectional microphone instead. If the distance between an instrument miked with an omni is about one tenth of that to the nearest other instrument you will not notice any bleed (I didn't say there won't be bleed, i said you won't notice it) and the proximity effect will be nil. One of the best dynamic mics I've ever used on electric guitar was an EV635A, it's an omni, has a frequency response out to 10K, will take a ton of level and you can cram it almost all the way into the grill cloth on an amp with no bleed and no proximity effect. As always YMMV!
Gigabyte z390 Designare
I9 990K 4.7 GHz
64 Gb of DDR4 3200
Gigabyte RX580 8 Gb
Win 10 Pro
15" Mid-2015 MBP 2.2 GHz i7 16 Gb RAM
512 Gb Flash Drive - OS X 10.14.6
"A VST Wrapper is a VST Wrapper" True or False? DBK AAX Plug-ins 9 12-23-2014 09:38 AM
MIDI CC - True of False eitw Pro Tools 11 19 09-22-2014 03:45 PM
Eleven Rack / Avid is not producing anymore Eleven Racks is that true or false? Rongpat Eleven Rack 8 02-11-2014 07:42 AM
New G4...false alarm.. Seller Pro Tools TDM Systems (Mac) 19 08-27-2002 06:11 PM
Pro Tools 5.1: Does it sounds better? TRUE OR FALSE??? joy4u Tips & Tricks 7 03-07-2001 11:14 PM
