Why do I hear an echo when I'm recording vocals
Ok, so when I go to record vocals I hear an echo of my vocals in my headphones?
I put the Mix volume tab all the way down and that eliminates the echo but then I cant hear the instrumental that im trying to record my vocals over. So my question is: How can I record my vocals onto an instrumental without hearing an echo and hearing the instrumental at a good volume through my headphones? Please help =D |
Re: Why do I hear an echo when I'm recording vocals
You could, lower the buffer down to 256, that works good enough, IMO, or run your mic and PT outputs through an external mixer so you hear no latency at all.
I do that alot. My 2 cents anyway |
by the way, welcome to the DUC, and what interface, PT version etc are you using?
I have the m-powered mbox 2
pro tools le. It was a factory studio bundle. And thanks for the welcoming!
Mbox is LE (confusing with the M I know)
Try reposting in the LE forum, I don't know how the mix works on the Mbox 2 But in settings Playback engine, set your buffer as low as you can. That will alleviate, the latency |
echo and volume issues when recording vocals | invaderslim | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-22-2012 01:34 AM |
Can't hear vocals while recording mbox2/Micro | blackpiano | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-30-2010 10:07 AM |
Echo while recording vocals | JoeLouis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 12-15-2009 05:54 PM |
Can't hear vocals during recording | mikecamp1978 | Pro Tools M-Powered (Mac) | 5 | 04-25-2009 01:45 PM |
hear vocals during playback w/o actually recording them? | Esteban | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 03-08-2002 12:59 AM |
