Old 02-17-2018, 05:27 AM
emminova emminova is offline
Default Collaborating surround with non surround users/output issues
Any suggestions for how a Pro Tools HD user could easily collaborate with another regular Pro Tools user? The HD user is doing a sound design mix in surround, but needs help on some sound design. So, he is sending me tracks to work on, but I don't have Pro Tools HD. So, I can change the outputs on the tracks so that I can hear them out of my basic stereo 1-2 output, but it then changes the outputs for the other engineer as well. Any way to share tracks without messing up the outputs?
Old 02-17-2018, 06:44 PM
Tweakhead Tweakhead is offline
Default Re: Collaborating surround with non surround users/output issues
Even if it can't address 5.1 hardware, can regular Pro Tools create a 5.1 bus ? If so . . .
1. Create a 5.1 Bus that acts as your assigned mixbus path for all tracks.
2. Create a 5.1 Aux Input with that same bus as its input, and assign its out to a 5.1 monitor path for your colleague.
3. Create another 5.1 Aux Input with that same bus as it's input, but insert the Avid DownMixer plug-in (found in the Sound Field category) as the last item in the insert chain. You will now have a stereo out, and all you need to do between you and your colleague is mute whichever monitor path you're are not using.
Old 02-18-2018, 09:57 AM
Unfortunately no, Pro Tools cannot create a 5.1 bus.
Cannot create surround 5.1 output / bus bassmagnetic Pro Tools 10 5 01-28-2018 09:04 PM
003 R for surround output nedd@nl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 01-10-2010 04:32 AM
Pro tools LE 8 and 003+ surround output jafbox Post - Surround - Video 4 10-27-2008 07:49 PM
Output Surround mix Yasgur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-25-2007 11:42 AM
96 I/O as a surround output on OS X? janmuths Post - Surround - Video 2 06-21-2007 05:25 AM
