Old 03-09-2004, 01:05 PM
MarcelD MarcelD is offline
Default X curve program-how?
Hi, I;d like to program an X curve on the master out of PT with a Plugin, but since the Xcurve must have a 3 db rolloff from 2 K, I do not seem to have an eq that makes a roll off slower than 6 db/oct. Any clues?
Marcel
Old 03-09-2004, 01:49 PM
georgia georgia is offline
Default Re: X curve program-how?
you need to program in an x-curve that actually creates the appropriate cuve based on your room. If you just program in a perfect x-curve it won't be right... You'll need to eq the room to create the x-curve.. So, before going much further, grab a pink noise generator, and A claibrated mic or four, and an RTA, then set the room to either Dolby Digital or DTS specs for either film or broadcast suggested monitoring levels for all speakers using pink noise generated at calibrated level to align the levels while monitoring the RTA. Then with tune the eq using pink noise running thru the plug-in. You may find that whatever plug-in yor using may just work fine. ( or not. ) IF it does and you get the right signal levels from the RTA in the room you will also then need to re-adjust the levels as you go. The specs are on line at dolby and DTS websites. I recommend that you use at least 4 calibrated mics set up within the listening area. Send the output of the 4 mics to a Time Division Multiplexer and into the RTA. You should set the four mics up within the listening area at a bit of random distances from one another ( not eaxactly equi-distant .
hope this helps
cheers
georgia
georgia hilton CAS MPSE MPE
Hilton Media Management
Film Doctors http://www.filmdoctors.com
Me... http://georgiahilton.webs.com/
Stage 32 http://www.stage32.com/profile/6569/georgia-hilton
My Production Company http://www.hiltonmm.com
CREDITS (partial) http://www.imdb.com/name/nm0385255/resume
MEMBER: IATSE LOCAL 700
HTML code is On
learning curve from PT Le 7 to PT 10 ?? diggyfresh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-13-2012 07:26 PM
Volume curve? aaron.ferrer Eleven Rack 3 12-06-2011 04:15 PM
A little behind the curve but...PT 7.4 OS 10.4.11 ??'s xxicjoy Pro Tools TDM Systems (Mac) 2 06-01-2009 05:26 PM
X-Curve and Levels Gordon Hookailo Post - Surround - Video 7 08-02-2008 10:27 PM
How can I see my EQ curve? uno1234 Pro Tools TDM Systems (Mac) 3 08-11-2005 02:15 PM
