Echo Audiofire 12 weird issue
Hi.
I am daisy chaining 3 Audiofire 12 cards into pt 10. It recognizes all BUT, Inputs 32-36 although showing signal on the cards and mixer view,but fail to show input in pt. I then assigned inputs 32-36 to a different card ,and now it's not showing input level on that card. When I select each card separate in playback engine ,all inputs work,just not as aggregate device. I'm using echo driver version 5.7.1 Any ideas would be appreciated |
Re: Echo Audiofire 12 weird issue
Alrighty then!
I found the answer myself. PT only supports up to 32 in and outputs!!! There you go. |
Sonnet Echo Express SE II Big Issue | Cryos | Pro Tools HDX & HD Native Systems (Mac) | 2 | 01-21-2015 02:17 PM |
Echo Audiofire 12 delay after a few minutes | halobend | Pro Tools 11 | 0 | 12-04-2014 03:53 PM |
Linking Two Echo Audiofire 12's for 24 inputs into Pro Tools HD 9 | Wave D | macOS | 3 | 12-29-2012 09:02 PM |
can't change buffer size pt 10 echo audiofire 8 | alexmusicboy | Windows | 3 | 12-20-2012 05:08 PM |
PT10 - Echo Audiofire 12 - How? | Vince_in_Windsor | macOS | 11 | 08-13-2012 06:42 AM |
