Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 04-09-2019, 05:43 PM
djjuniorpops's Avatar
djjuniorpops djjuniorpops is offline
Default UVI Workststion
I seems to cant get my copy of UVI Workstation to show up in Pro Tools First.
Any assistance would be appreciated,
Old 04-09-2019, 05:53 PM
amagras amagras is offline
Default Re: UVI Workststion
PTF can't use external plugins
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 04-09-2019, 07:32 PM
jeffro's Avatar
jeffro jeffro is offline
UVI Workstation is included with Pro Tools First.
More info please... Did you download/run the installer from my.avid.com/products? What version of PTF? What OS version?
linkedin
Old 04-10-2019, 09:55 AM
I am using the latest version in my Avid account, I am using version 3.0.5 of UVI Workstation downloaded from my Avid account.Version 10.13.6 0f Mac OS.
Old 04-10-2019, 02:41 PM
jeffro's Avatar
I installed UVI Workstation 3.0.5 and PTF 2018.7 from my.avid.com/products and it's working correctly here (I'm also on macOS 10.13.6). Shows up in the inserts on a stereo Instrument/Aux track (not mono) in multi-channel plug-in > Instrument. Can you confirm you're using a stereo track?
linkedin
Old 04-10-2019, 03:34 PM
I can confirm that I am doing all of the above and still no luck.
Old 04-13-2019, 10:17 AM
I delete all files for PTF and UVI Workstation and re install both software and it still do not work. I am also getting a message from the stand alone version of workstation saying that, unable to mount Plugsound.ufs (Not a valid host)
Old 04-13-2019, 02:22 PM
jeffro's Avatar
Sounds like that dialog is normal for that... support.uvi.net/hc/en-us/articles/360000706997-Error-Message-Not-a-valid-host-
You could try deleting InstalledAAXPlugIns from /Users/*name*/Library/Preferences/Avid/Pro Tools so that gets recreated on launch of PTF.
I just added you as a contact and can invite you to a Project to test this further.
linkedin
Old 04-13-2019, 02:42 PM
DetroitT's Avatar
DetroitT DetroitT is offline
"Unable to mount the Volume from [Path to the UFS soundbank] (Not a valid host)"
This means you are trying to use a product which is aimed to be loaded exclusively in your DAW as described by the DAW manufacturer.
All Free is not Free
t
Old 04-13-2019, 08:36 PM
Jeffro tried all of the above still no luck, I guess I would just delete PTF and stick with Logic X, to much issues with installation of PT.
