Old 06-23-2010, 06:49 AM
mangoustine mangoustine is offline
Default Multi-mono Signal Generator TDM out of phase !!!
Hi everyone,
I was calibrating the studio (PT HD3 8.0.4, DM2000) this morning when I discovered a phase problem (read on my RTW PPM).
So I looked around for the cause, and I found that it was the Signal generator plugin that was out of phase !!!
I switched it to RTAS, and the problem was gone ! Back to TDM => Out of phase.
So Digitechs, I don't know how to submit a bug report, but I would like to, and I also want to be sure that only signal generator is affected...
Old 06-23-2010, 07:07 AM
jeremyroberts jeremyroberts is offline
Default Re: Multi-mono Signal Generator TDM out of phase !!!
use a mono sig gen and bus it
PS --
http://duc.digidesign.com/showthread.php?t=256845
--Jeremy
Old 06-23-2010, 07:15 AM
James Drake James Drake is offline
a multi-mono plugin as just that, it is two instances of the same plugin.
the two instances are not synced in anyway.
if you has two oscillators which were both set exactly the same, sitting next to each other, would you expect them to be phase locked?
Old 06-23-2010, 08:16 AM
OK. So, why is the RTAS version perfectly in sync ? By the way, when I insert a mulit-mono plugin (because there's no multichannel version), I expect it to be in sync...
Also, you can try this :
1) Create an Aux track
2) insert a TDM multi-mono signal generator
3) if you have an external phase meter, you should see it's not in phase
4) insert a TDM multichannel Phasescope => now it's in phase
5) Make the signal generator inactive, then reactivate it => not in phase
6) switch signal generator to RTAS => in phase
7) switch it back to TDM => not in phase
I don't think this is a normal behavior... but I might be wrong.
Old 06-23-2010, 09:27 AM
kazuomik kazuomik is offline
Why do you need to insert Signal Generator to the stereo track ?
I think the mono track is enough for Signal Generator, and that it might be technically designed only for mono.
Old 04-15-2019, 04:53 AM
martthie_08 martthie_08 is offline
I can't believe this is still not fixed a gazillion versions later on HDX running Ultimate 2018.12
Signal generator TDM out of phase.... Kroger Pro Tools TDM Systems (Mac) 11 04-05-2009 12:50 PM
Phase coherency (multi-mono vs Multichannel) Ray Fabi Pro Tools TDM Systems (Mac) 0 01-21-2006 02:56 PM
Signal generator out of phase garret Pro Tools TDM Systems (Mac) 12 12-01-2005 10:19 AM
I Need Clarification. Difference between Multi Channel and Multi Mono Plugs citi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-13-2002 11:08 AM
Multi Mono vs Multi Channel Plugins...Just curious... Mr T 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 03-18-2002 09:46 PM
