Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 05-09-2019, 02:29 PM
rinky rinky is offline
Default -9173 Error Finally Gone?
Is the infamous -9173 error finally eradicated with 2019.5 update?
PT Ultimate 2019.10
PT HDX
Magma ExpressBox3T PCIe Thunderbolt Exp Chassis
Blackmagic Multidock, SSDs
iMac Pro
64 GB ram
OS X Mojave
Somehow, musicians are now technicians!
Old 05-09-2019, 05:46 PM
tclash tclash is offline
Default Re: -9173 Error Finally Gone?
Got one in the first few minutes of using 2019.5.
Old 05-09-2019, 06:03 PM
Yikes!!! Out of all the massive bug fixes listed for this release, the most notorious is still not fixed.
Wow...
PT Ultimate 2019.10
PT HDX
iMac Pro
64 GB ram
OS X Mojave
Old 05-09-2019, 07:54 PM
amagras amagras is offline
And freezing tracks is still the same hang fest
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 05-09-2019, 09:08 PM
The premise of this thread is a little silly. AAE-9173 is not going to be “gone”. That’s an important error that will always still be possible if you load up a system enough, or have a bad plugins.
2019.5 is obviously a huge amount of work from Avid, with what so far seem like very impressive improvement in threading that reduces issues that were contributing to 9173 errors before for many users. See other posts on threads here about that already. Will it stop all 9173, no, that is impossible. How will it work for you? With your plugins, sessions and workflow? Don’t know. Try it. Have a recovery plan.
Old 05-10-2019, 04:27 AM
Jamie Mac Jamie Mac is offline
Still getting completely random and unidentifiable -9173 errors while CPU usage is hovering at 10% in a session with
There is no pattern that causes it.
It just happens about twice a day (in 2018.12) and I've had it happen now after about 2 hours of mixing today in 2019.5
Old 05-10-2019, 04:42 AM
Have you troubleshot your plugins (removing the .aaxplugin files)? Looked for Fully optimized your system? Tried other troubleshooting? Larger IO buffer size? Is disk cache turned on. Try a different playback engine? Etc... what OS are you on? Have you tried disabling hyperthreading (esp. If on Mac/Mojave) if it was disabled try reenabling it with 2019.5.
Old 05-10-2019, 04:54 AM
Yes, my system was and is fully optimised.
The error is completely random and is a known issue that has not been resolved in 2019.5
Old 05-10-2019, 06:17 AM
Basstian Basstian is offline
Windows or Mac OS?
Mac Pro 3,7 GHz Quad-Core Intel Xeon E5
Mac OS 10.14
ProTools Ultimate 2018.12
Video Slave 3.4
Old 05-10-2019, 08:41 AM
Yodah Yodah is offline
Nope...
Its weird I still get the 9173 error as well, trashed prefs and everything!
It will be running smooth, cpu usage in protools will be at around 12% on a session with 110 tracks 24/48, I set the buffer at 32 with about 50 plugins (mostly UAD). And out of the blue it will stop about 3/4 of the way through a song CPU meter never rises above 12%....
Now is it crippling me, of course not. I would love to be able to pinpoint the issue but I know if I move it up to 128 or higher the likely hood of the error drops dramatically
Its random, but its definitely something else causing it and not computer processing power...
PT 2019.5 on Mojave
MacPro Late 2013 6 Core 64gb 512ssd
Slate Raven Mti2 Core
Apollo X6. Apollo Twin.UAD2 Satellite
BLA XB Clock
SSL Fusion
AAE error -9173 nikydvt Pro Tools 12 11 01-14-2017 05:05 PM
AAE error -9173 on PT 12.4 marcnyc Pro Tools 12 2 06-24-2016 04:27 PM
Error -9173 music.m Pro Tools 11 1 03-19-2015 10:42 AM
PT 11 Clearly Not An AAE 9173 Error rgconrad1 Pro Tools 11 3 09-30-2014 12:56 AM
