Old 12-17-2015, 04:48 PM
cellopoet cellopoet is offline
Default Pro Tools 12 with Ableton Live
I've been thinking of upgrading to Pro Tools 12, but before I do I want to be sure it will run Ableton Live as a Rewire slave. I have PT 11 and Live 9, but was having to use PT 10 and Live 8 because of the compatibility issues with the newer versions. I'm wondering if these issues have been solved now in PT 12. Will it work with Live 8 or 9? Does anyone know? Haven't been able to find anything online about it yet. Thanks in advance.
Old 12-21-2015, 12:56 PM
Shan's Avatar
Shan Shan is offline
Default Re: Pro Tools 12 with Ableton Live
What issues were you having? One thing to keep in mind is that your ReWire programs need to be 64-bit for use with PT 12.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 12-21-2015, 08:11 PM
Ableton Live 8.4 and on wards supports 64-bit.
Aaron Mulqueen - 001 HD Native
Old 12-23-2015, 04:38 AM
Axel_L Axel_L is offline
Hi everyone,
I just installed Live 9.5 (x64) on win7.
I have searched for weeks now and I still can't fix the issue with PT12 rewire.
Maybe I'm doing something wrong.. I hope you can answer to cellopoet.
All the best,
Axel
Old 12-23-2015, 07:08 AM
Shan's Avatar
What's the issue?
Shane
Old 12-23-2015, 09:22 AM
I can't see ableton live in PT, even if I launch live before PT.
Thanks for your help
Axel
Old 12-23-2015, 03:09 PM
I had been getting the error: "The ReWire application has detected a difference version of Live than the one last used. Please quit both the current ReWire master application and Live, then launch Live once as a standalone application so that it can install its ReWire engine."
Following the instructions of the message (relaunching as standalone) did not help. This was happening during the transition to 64-bit. I had been trying to use Pro Tools 11 with Ableton Live 9 (or 8, I don't remember exactly which version I had at the time). Because of this Avid had allowed people to have both PT 10 and 11 authorized on the iLok, so that when I needed Ableton, I could use PT 10 and when I didn't need Ableton, I could use PT 11. I was just wondering if anybody is now successfully using Ableton Live 9 as a Rewire in Pro Tools 12.
Old 12-26-2015, 06:02 PM
Shan's Avatar
Make sure the following exist in your system:
  • C:\Program Files\Avid\Pro Tools\System Plug-Ins\DigiReWire.aaxplugin
  • C:\Windows\SysWOW64\ReWire.dll
Shane
Old 12-26-2015, 09:16 PM
Top Jimmy's Avatar
Shane
I don't have a Rewire.dll in the SysWOW64 folder and Rewire still seems to be working ok. I don't have Live installed though.
This video should still be relevant.
http://youtu.be/fDV1n2MIIGg
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Sierra 10.12.6.
Pro Tools HD 2019.10, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Old 12-27-2015, 08:09 AM
Shan's Avatar
Interesting. Reason shows up for me in PT 10, but there's no registry key for it as demonstrated in your video. Hopefully we can find a definitive solution on the Ableton side.
Shane
Ableton Live in Pro Tools 11 stuartmid Pro Tools 11 2 12-17-2014 07:40 PM
FS Pro Tools 10 / Ableton Live Suite 8 Rackinator Buy & Sell 1 05-03-2013 03:38 PM
Ableton Live 8 & Pro Tools wfasano 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-21-2009 04:16 PM
Pro Tools LE vs. Ableton Live 5 ccastillo123 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-15-2005 12:11 PM
Ableton Live and Pro Tools Joseph Anderson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-08-2002 06:07 AM
