Old 08-15-2009, 10:56 PM
jdjurado jdjurado is offline
Default Hardware Recommendations
What do you guys recommend for hardware improvements? I just installed Protools LE 8 and it runs just a bit slower than I'd like. Here is what I currently have:
AMD Athlon 64 X2 Dual Core (4800) 2.5Ghz
4 GB RAM
ATI Radeon X1200 Series Video Card 256 MB memory
640 GB, SATA 3 Gb/s, 32 MB Cache, 7200 RPM Western Digital Hard Drive
Windows Vista Ultimate 32 bit Service Pack 2
Thanks for any input!
Old 08-16-2009, 01:43 AM
mano111 mano111 is offline
Default Re: Hardware Recommendations
What do you mean by "slower"?
Do you have a dedicated audio drive? (its a requirement)
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD
PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9
Old 08-16-2009, 07:20 AM
I don't know if Digi has approved SP2 yet. The intel quads (Q9550 or i7 920) stomp all over any dual core system. Using a second internal SATA drive will perform better than firewire. I generally only use firewire drives to transfer to other studios.
Old 08-16-2009, 12:23 PM
Do you mean a dedicated Hard Drive for audio files for Protools to use?
By slower, I mean that, compared to Cubase LE 4, my computer seems to be a bit overwhelmed in terms of CPU resources being taken up
Old 08-16-2009, 12:24 PM
Albee, so you're saying that a quad core is definitely recommended? How about a better video card, would that do anything for me?
Old 08-16-2009, 12:29 PM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Quad core is just better for obvious reasons than what u have to be candid(as I usually am)...
as for a better vid card, it would NOT do it for u...
As in comparing Cubase & PT8 STOP IT!
@ totally different things & remember, or know if u don't, that PT is a REAL-TIME sample based DAW unlike any other which is why it would need more power & ur Cubase can run fan on what u have...Its not REAL-TIME...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 08-16-2009, 12:32 PM
lol, i appreciate your candidness :) I promise i will never again compare Cubase and PT. Thanks for the tip on the quad core; I just wanted to make sure PT actually took advantage of multiple cores
Old 08-16-2009, 12:34 PM
Well I already have an AMD motherboard, so what do you guys think of a AMD Phenom II X4 940?
Old 08-16-2009, 12:37 PM
Well it most certainly is... & No prob
As for that processor, thatz out of my league... Can't be candid on that 1
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
Old 08-16-2009, 02:44 PM
If you are familiar with the Dverb test(a stress test to benchmark a Pro Tools LE system), then I can tell you my older AMD 6000+ (dual 3 GHz) topped out at 104. My new intel i7 quad more than doubles that number(other users are doing triple that number). You absolutely must record to a separate hard drive(not a partition of the system drive). USB drives are NOT supported. Firewire drives need an Oxford chipset. Firewire ports(either on the motherboard or on a card) should have a TI chipset(some others work and some others don't). eSATA also works fine but adding an internal drive is the cheapest and best performing setup(nothing beats a good SATA drive at 7200 rpm with 32 meg cache). 10K drives are not worth the extra money(my opinion only) as they offer no real performance boost over 7200 rpm. Poke around the Windows section of the DUC to see opinions on the Phenom quads. Also, check the manufacturer's website for your motherboard to see if its compatible with the newer Phenom II cpu's.
"Unable to locate M-Audio hardware. Make sure your hardware is connected and turned o MerryD Pro Tools SE and Essential (Win) 8 08-02-2012 01:59 AM
unable to locate m-audio hardware. make sure your hardware is..works fine in ableton? pein Pro Tools M-Powered (Win) 2 10-07-2009 01:01 AM
hardware recommendations for getting a MBPro to work with DIGI003 wishesonaplane 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 20 05-05-2009 06:23 AM
Hardware recommendations? Kleekoh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-23-2003 09:19 AM
Hardware Recommendations For 002 August Heat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-20-2002 01:06 AM
