Old 12-14-2019, 12:35 AM
acmost acmost is offline
Default How to Automate MuteTone
I have PT 9HD that I use with an Apollo, I mean I can use the Apollo Console & I do from time to time but how do you automate MuteTone?
I want it to come on when I press record and off when I don't instead of having to hit bypass on the plug all the time. Is it an IAC HUI midi thing which i am pretty clueless about or...? Surely you have to be able to do this?
TIA!
Old 02-01-2020, 05:18 AM
Default Re: How to Automate MuteTone
hahaha...not much luck here.
Old 02-01-2020, 10:18 AM
The Weed's Avatar
The Weed The Weed is offline
Are you just wanting to mute the record track? If so, go into Preferences and UNlatch record and play faders. In record, pull the record fader to the bottom. When you take the track out of record the play fader will be at 0, when you put the track back in record, the record fader will be at the bottom.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 02-04-2020, 11:31 AM
Hmmmmm...I shall try this!
Old 02-04-2020, 04:52 PM
The Weed's Avatar
If it is what you want and works for you, make a template with all the record tracks' faders at the bottom.
SonoBus
Old 02-06-2020, 07:28 AM
I tried it but it didn't work like that, I'm going to check it out again though.
Old 02-06-2020, 10:14 AM
The Weed's Avatar
You have to Unlink the Record & Play faders in Preferences, then, when the track is in record, lower that track's fader to the bottom so no signal passes.
SonoBus
Old 02-08-2020, 07:29 AM
Hey thanks for taking the time, it worked! It doesn't quite accomplish what I'm trying to do but I'm glad I learned how to do that. Thanks.
[IMG] code is Off
MuteTone update dr_daw Pro Tools 10 0 02-09-2014 03:12 PM
MuteTone is now 64-bit AAX for Mac mesaone AAX Plug-ins 0 02-04-2014 11:05 AM
MuteTone AAX? jacko AAX Plug-ins 1 01-22-2013 01:45 PM
PT 10 and mutetone bradswan1 Pro Tools 10 6 11-06-2012 03:48 AM
Mutetone and Command 8 together? Blues Bird ProControl, Control|24, Command|8 0 08-20-2012 02:04 AM
