Changing DAW. Suggestions?
I Currently have the mbox 3 interface with pro tools express. Im getting a new conputer and i no longer have the pro tools express installation disc.
I was just wondering what you guys would recommend for a digital audio workstation preferably one that works with the Mbox 3 interface |
Re: Changing DAW. Suggestions?
The Mbox, to work with other programs on a PC, requires an ASIO driver. If you have/can find that, then any DAW that uses the ASIO protocol can use the Mbox. If the ASIO driver is part of the PT Express install, then you're obviously going to need the installer.
Per your other thread, you need to solve the BSOD you're experiencing. That may allow you to continue working with your current computer.
Mbox asio drivers are available online.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro PT 2023.3 Studio through an A&H Qu-32 |
Give Pro Tools First a shot and see if you still want to stick with PT.
There are plenty of others out there and everyone has their own favorite, so I suggest downloading some demos and seeing what fits your needs. |
Laptop user - changing HW engine - suggestions? | BCnSTL | Pro Tools 11 | 0 | 06-26-2014 11:28 AM |
Changing note values while changing meter - I'm stumped | jrmintz | Pro Tools TDM Systems (Mac) | 4 | 10-30-2011 03:55 AM |
changing tempo without changing pitch | Sharabelle | Pro Tools TDM Systems (Mac) | 3 | 02-10-2007 05:19 PM |
Changing tempo w/out changing midi performance??? | toddm7 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 11-12-2005 10:35 AM |
changing tempo without changing midi | wizdoom | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-20-2004 05:40 AM |
